Hot Rods I want a real definition between 2 barrel carbs and 4 barrel carbs
Discussion in 'The Hokey Ass Message Board' started by CokeandSmoke, May 22, 2018.
  1. CokeandSmoke
    CokeandSmoke
    I want a real solid answer between the two. One that will go down in history! My uncle says the small blocks don’t need em so what?!
  2. Torana68
    Torana68
    from Australia
    If you happy with a low HP engine stick with the two barrel, so no , v8 engines don’t “need” one or more 4 barrels. Now if you want more HP you do “need” one or more 4 or maybe multiple 2’s
    OahuEli likes this.
  3. gimpyshotrods
    gimpyshotrods
    He's right.
    Only biological entities have needs.
    Inanimate objects don't.
    sko_ford, Squablow, blowby and 5 others like this.
  4. squirrel
    your uncle ain't a hot rodder, so don't listen to his car advice
    verno30, R A Wrench, OahuEli and 10 others like this.
  5. Your uncle is right.
    You two should define "need"
    Now,,,,, the engine lives a better life worth living with more air and more fuel
    '51 Norm and loudbang like this.
  6. Squirrel is Correct!
    To add to what 31 Vicky with a Hemi said. Once you mount the more air and more fuel system, in order to make them work the best they can you must add a different Cam profile and a better set of Heads. Pretty soon you'll have a real Hot Rod.
    Your Uncle may be right about the Motor and it's needs. Generally it's the Driver that has the Need.
    The Wizzard
    Spooky and loudbang like this.
  7. Deuces
    Deuces
    232144-1288659372-5e83f33ae6a9127adccbdb1fd083dd00.jpg What other reason do you need????....
    Spooky, OahuEli, CAHotRodBoy and 4 others like this.
  8. Mike VV
    Mike VV
    from SoCal
    Coke wrote -
    Yeaa...exactly WHAT doesn't a small block NEED, please clarify ? What's "em" stand for ?
    If you are talking a four barrel carburetor, what has been written above is pretty much correct.
    Mike
  9. DDDenny
    What was the question?
    czuch likes this.
  10. Rickybop
    Rickybop
    verno30, 55Deso, dan31 and 6 others like this.
  11. Well, there's something to be said about efficiency...
    I do know that a typical mid-'70s lo-po 350 Chevy with a factory 2V could show a real improvement in fuel economy by switching to a 600 CFM vacuum-secondary Holley, as well as gaining power at the top end. The two barrel was a compromise; it had to be big enough so the motor wasn't badly starved at high RPM, yet was too big at low speeds as velocity through the carb was too low for the best fuel atomization. The smaller primaries on the 4V would usually gain you 1-1.5 MPG with no other changes.
    Those 500 CFM 2V Holleys were real dogs on the street. MPG in the low 10s or less around town wasn't unknown.
    Nailhead A-V8 and cavman like this.
  12. pontman
    pontman
    My advice is don't listen to your uncle.
    hrm2k, tractorguy and bobss396 like this.
  13. southcross2631
    southcross2631
    GM spent millions on testing and if a 2 barrel was enough then then why did put 2- 4 barrels on a small block. Tell your uncle that opinions are like assholes, everybody has one.
    tractorguy and Deuces like this.
  14. i wonder if he/you misunderstood the question/answer. could he have been arguing over the need for two four barrel carbs? or multiple carbs versus one big four barrel?
    Saxon, Hnstray and Just Gary like this.
  15. Lol
    Does it need it? No.
    Does it want it? Yes.
    Kinda like asking , do I need that 5th beer? No, do I want it? YES !!
    OahuEli, lothiandon1940 and '51 Norm like this.
  16. 62rebel
    62rebel
    funny how the title of the thread implies one question and the content of the thread implies another. Going by the title, a 2 barrel carb has two venturi; and a four barrel has four. Going by the content of the first post; an engine needs whatever it takes to get the job done for which it is intended. If you're putting around in a grocery-getter sedan, never going over the in-town limit, two barrels will do you just fine. If you're looking for getting from, say, Bakersfield to Hemet in a couple of hours, you might want a couple of fours and the requisite manifolding and cam work....
    LM14 and Hnstray like this.
  17. wicarnut
    wicarnut
    Need/Want, Who's on First ?
    tractorguy likes this.
  18. Hundreds of millions upon millions of miles - trouble free miles using a 2 Barrel carb. Many of those miles at far above the legal speed limits
    tractorguy and Blues4U like this.
  19. carbking
    carbking
    Not certain I understand what is being asked. Does the OP wish to know if a small block Chevy needs a four barrel, or does he wish a treatise on the difference between two barrel and four barrel carbs?
    Just for the record, two barrel carbs have been used on some fairly good sized engines (one on a 1792 CID V-12).
    And a single barrel (that is correct, a one barrel) was used on a 5053 CID 8 cylinder.
    Often, progressive carburetors (virtually all four barrels) are used on engines with a wide RPM range to optimize engine efficiency over the range. Which is why some of the screamer 4-banger in the 1970's and 1980's used progressive two barrel carbs, even though sufficient air flow was easily obtainable with a one barrel.
    Have converted MANY engines (for street use) to more carburetion ALWAYS with an improvement in fuel economy as well as power (well, the fuel economy would depend on the driving habits of the operator).
    Jon.
  20. We might as well make this thread interesting.
    Why are 2bbl carb CFM measured differently the 4bbl carb CFM?
    And what's the conversion factors to get a true apples to apples comparison.
  21. flynbrian48
    flynbrian48
  22. carbking
    carbking
  23. I may not need a bigger penis.
    Frankie47, redo32, Just Gary and 2 others like this.
  24. Most years I can think of, back before F/I, car manufacturer's V8 offerings could be equipped with either a 2 barrel or a 4 barrel set up. If City Hall went to the dealer to purchase a couple of 4-doors and one was for the police department, it "needed" a 4 barrel. And if the other was for the water meter reader department, it "needed" a 2 barrel.
  25. Get far away from that uncle....... you don't need that negativity in your life
  26. Paul
    Paul
    Editor
    your uncle says small blocks don't need carburetors?
    he may have a point..
  27. Deuces
    Deuces
    Yep! They look better with injector stacks.... All 8 of them.....
  28. B.A.KING
    B.A.KING
    Well, think about this, sometimes the factory even put 3 2bbl carbs on a engine......................................
    Ask ole unk about this..........................
  29. FrozenMerc
    FrozenMerc
    Go find a Stromberg PD-18 (generally attached to the inlet of the supercharger on Series 68 and 69 Rolls Royce Merlin V12's and Packard V-1650 engines). 2 Barrels of updraft fun. They can be identified by the 5 7/16" throttle bore. That's right, the throttle plates are considerably bigger then the piston bore on any small block.
    2 or 4 (or 3 or 1 or 6 or 8) barrels on a carburetor is meaningless without the context of the engine it is used on. The carbs job is to meter fuel and air. How it does that and its construction are defined by the OEM design engineer. Most of the time, cost is the primary consideration, with performance following behind. And when Holley or Carter or Rochester are using most of the same parts to build a 2 bbl or a 4 bbl, the OEM will take the 2 bbl every time on a lower cost model.
  30. DDDenny
