Technical I.D. EXHAUST MANIFOLD...
Discussion in 'The Hokey Ass Message Board' started by banditomerc, Feb 24, 2021.
  1. banditomerc
    banditomerc
    Need help guys. What year /make? Will it fit chevy 1969 350 engine. Is it 2" exhaust?The seller says its 265 chevy,but I dont remember seeing anything like this for 265...any help is appreciated..
  2. looks like a big block MOPAR
    das858 likes this.
  3. squirrel
    mgtstumpy, Paul, 47chevycoupe and 3 others like this.
  4. :D :D that was my second guess. All a big block MOPAR is, is an SBC with an external pump. :D :D
    Hnstray likes this.
  5. squirrel
    and no, it's not a 265 manifold, although it's slightly similar looking. The 265 had the dump near the front, not the back.
    and it will fit a 69 350. You'd have to measure the outlet size, I expect it's probably 2" or close to it.
  6. These are early 265 manifolds- similar, but not the same:
    Deuces likes this.
  7. Bob Lowry
    Bob Lowry
    Mopar, 383", '66 to '69..check ebay....
    Deuces and porknbeaner like this.
  8. Budget36
    Budget36
    Unless it’s ground off, wouldn’t the casting number narrow it down?
    Bob Lowry and Deuces like this.
  9. squirrel
    I already told you what it is....
  10. scrappybunch
    scrappybunch
    from nj
    It's from a 80's Malibu with a 267 or 305
    flatford39 likes this.
  11. BigDogSS
    BigDogSS
    from SoCal
    For a SBC, you are better with 2" ram horn manifolds. As long as they fix your chassis. They are not hard to find.
  12. banditomerc
    banditomerc
    Ram horn on drivers side causing me headaches...need a rear dump to clear steering shaft..
  13. TCATTC
    TCATTC
    G body GM V8 Drivers side
  14. Bob Lowry
    Bob Lowry
  15. squirrel
    not quite...it's very similar, but different The G body manifold
    https://www.dormanproducts.com/p-5452-674-276.aspx
    has an o2 sensor hole on the front of the outlet part,
    while the truck manifold in the first post,
    is like the one in my link above....
    jimmy six and scrappybunch like this.
  16. TCATTC
    TCATTC
    The truck manifolds that look like that have a three bolt flange, the G and A body ones have a two bolt flange.
  17. I think Squirrel is right, note the bosses where the air pump system would be drilled in if it called for it. Those will fit a gen 1 sbc, most likely a 2" port and should be way cheaper then a 265 manifold.
  18. I thought it was 70s V/8 monza...
  19. jimmy six
    jimmy six
    warhorseracing likes this.
  20. jimmy six
    jimmy six
  21. squirrel
    one thing about those, is that they only work with later heads that have the extra hole at the end. The two bolts on the left end, are farther apart from each other than the two on the right.
    1oldtimer likes this.
  22. Wayne3207
    Wayne3207
    from WestTN
    The one in the original post is/was also used on mid 80's Firebirds and Camaros with 305 engines. These had the A.I.R tubes added.
  23. You're right. I Googled sbc exhaust manifolds, saw those and posted. Sorry for the bad info.
