I'm looking to put a V-gate in my 56 Chevy with a Muncie. I have a Comp Plus now. Does anybody know if the shift rods are the same or will work? Thanks!
If I remember correctly, V-gate mounts high and has straight shift rods, the other mounts in the normal position with the bent rods to fit.
why do you want to replace the comp-plus with an inferior shifter? and ruin your floor in the process.
Rods are different. I have had both and currently have a V-Gate in the 55. Have never missed a shift with the V-Gate
Are you talking about the Ram Rod shifter or the Verta-gate from my past experience the Ram Rod shifts really nice and the Verta-gate I wouldn't put on my worst emery car. Also are you going to use this on the street because they don't down shift very well there is a trick to down shifting them. If your missing shifts should look at your linkage adjustment. Comp.Plus Shifter are the best in my book.
Thanks for all the feedback. It's a drag car, so street driving isn't an issue. It is a V-gate and not a Ram Rod. I've got a couple friends that like them. We'll see what happens.
