Technical Hurst motor mounts
Discussion in 'The Hokey Ass Message Board' started by robbins, Nov 7, 2018.
  1. robbins
    robbins
    from Missouri
    I have what I think are Hurst motor mounts, but they don't have any identifying marks.. .any help would be helpful. Thanks in advance.
  2. MikeC62
    MikeC62
    from Missouri
    Looks like early Hemi to me
    Bandit Billy and robbins like this.
  3. tubman
    tubman
    Same here. If you want to get rid of them, PM me.
    robbins likes this.
  4. 73RR
    73RR
    Yup, EarlyHemi. If you clean them up real good they will say Hurst unless they are re-pops lilke mine which are not marked.
    They also fit on early Cad blocks....
    gimpyshotrods and robbins like this.
  5. robbins
    robbins
    from Missouri
    Cool this is the info I was looking for. Do you know who had repopped them, for these are not marked. Thanks again...
  6. Could be Trans-Dapt. Definitely early hemi.
    robbins likes this.
  7. robbins
    robbins
    from Missouri
    Cool..... didn't realize that Trans adapt have been around that long.
  8. They could be for Cadillac if the block mounting holes are 7/16", or Chrysler if the block mounting holes are 1/2" diameter. there was a guy in Massachussets that was making re-pop Hurst mounts for Oldsmobiles, and Chryslers. I don't know if he is still making them.
    robbins likes this.
  9. rudestude
    rudestude
    robbins likes this.
  10. 19Fordy
    19Fordy
    61cad, fauj and robbins like this.
  11. robbins
    robbins
    from Missouri
    Awesome guys....thanks for the help
  12. robbins
    robbins
    from Missouri
    These where on it when he got it back in the mid 90's. and been on the motor awhile cause they were covered in thick grease and grim like the rest of the motor. LOL
  13. 73RR
    73RR
    No way to know how many folks have made the various Hurst mounts. I have been making the EarlyHemi piece for about 10 years.
    robbins likes this.
  14. robbins
    robbins
    from Missouri
    Thanks again for your guy's time
  15. Studebaker.......
  16. gimpyshotrods
    gimpyshotrods
    Pretty sure they went into business just after the automobile transmission was invented.;)
  17. Beanscoot
    Beanscoot
    Although the instructions only list the Chrysler engines, these would fit the Dodge and Desotos as well, right?
  18. Brand Apart
    Brand Apart
    from Roswell GA
    Not likely , as far as I have found absolutely no parts are the same between the 3. I own a Chrysler and a desoto. Of course neither are running yet so I'm far from an expert
  19. Beanscoot
    Beanscoot
    Well the bellhousing pattern is the same (excluding the extended bell), so it's possible the mounts are as well.
  20. 73RR
    73RR
    Ears on the blocks (51-58)(Hemi, poly and A) are the same.
    The distance from the back of the block to the ears as well as the distance from engine centerline are different between the three.
    Beanscoot likes this.
  21. Beanscoot
    Beanscoot
    "The distance from the back of the block to the ears as well as the distance from engine centerline are different between the three."
    What in tarnation were the Chrysler engineers thinking? Make work projects?
  22. Who knows, maybe the engineers gave all the different divisions basic blueprints with no sizes or numbers on them? o_O
  23. Beanscoot
    Beanscoot
    When I first started reading up about these early Hemis many years ago I marveled at how the Chrysler Corporation could afford to design, engineer and build three series of engines that were all slightly different, so all the blocks, cranks, etc. had to be independently made up.
    Maybe the transmission department laid down the law and said "only one bellhousing pattern!" Well other than the integral style, of course.
