How wierd is this?
Discussion in 'The Hokey Ass Message Board' started by panheadguy, Aug 14, 2006.
  1. panheadguy
    panheadguy
    from S.E. WI
    Background info. I have a 292 Chev six in my '37 Chev pickup. The motor is mildly built with a cam, .060 overbore, and my carb is a 390CFM Holley 4bbl.
    This thing whistles in the carb like a MF. At cruising speed it is almost enough to drive me to distraction. I can modulate the noise with throttle, but not much. I have changed air cleaners with no help. No air cleaner, same shit.
    It's a good thing I don't have a radio 'cause I couldn't hear it anyway.
    Anyone got any idea how to cure this?
    PanheadGuy
  2. chrisntx
    chrisntx
    from Texas .
    look for an air leak
  3. 53sled
    53sled
    from KCMO
    I had a 300 ford that did that, it was an intake leak that was hard to spray carb cleaner in, so I had a hard time finding it, but thats where it was. ran ok, but whistled LOUD on hot days.
  4. I'ts a vacuum leak. Find it,fix it and will run much better
  5. Toystoretom
    Toystoretom
    Are you running an adaptor between the 4 bbl Holley and possibly the two bbl straight six intake manifold? Or just an adaptor period? I have had those adaptors whistle. There really was no intake leak, it was just the shape of the 4 down to 2 that did it. I had to grind a little away and reshape things a tad.... It only whistled under a hard throttle, you could almost play a tune with it... This is why you should only use six one barrels :D
  6. RATCAMINO
    RATCAMINO
    hell don't fix it it my keep deer from jumpin out at your ride lol
  7. Had an oil cap sucking air [thru its gasket] made the same screamin sound!
  8. panheadguy
    panheadguy
    from S.E. WI
    Lots of good ideas here and i'll check them all out. Thanks for the help.
    Guy
