Hello guys. I started to work on my 62 econobox this summer. I pulled the 200ci out of it to clean and paint it. I was really happy to see a reconditioned tag on the block and clean top under the valve cover. I pulled the oil pan off today but before prying it off with a screwdriver, I hit the sides with a rubber mallet. The engine was almost upside-down. ,when I pulled the pan,there was some big grit on the bottom but im afraid that some fell inside the bottom end.. I can't see anything tho. The grit was not magnetic,almost like carbon build up and a tiny sliver of glass. Should I be worried? Is there a way to flush everything down? I will have more questions as I put this beast together. Thanks hamb.
Turn the engine right side up or valve cover side up and get two cans of brake clean put the red plastic tube on the brake clean and spray up from the bottom that should wash it out
Good technique. I use a normal garden sprayer for similar jobs. Diesel is a cheap solvent for the first step. Follow up with a lighter, faster dry solvent of your choice. I've even used a pressure washer followed by a l o n g session with compressed air to dry the water out. Depends mostly on your available solvents and work environment. In my shop a big piece of cardboard will catch and soak it up. Guys working in a residential drive in view of neighbors may have different constraints.
You can get a small 1 quart spray thing that hooks up to a tire chuck from you're compressor line. I then spray with diesel fuel, scrub with the parts washer brush, spray again, and let it all fall into one of those cheap pans from nappa. all right side up, as noted above
Like the man said earlier,,,a few cans of brake cleaner will fix it up ,,,,and quickly as well . Turn it right side up,,,,and spray the dickens out of the inside,,,,,,gravity will flow anything out . I’m assuming you were talking about dirt and grit that was on the outside of the pan ? It looks like you got a really good reman ,,,,,at least it looks good to me . I’m just assuming the condition is good internally,,,,the timing chain looks good and tight . Good luck . Tommy
I'm on the gravity is your friend bandwagon, but would not use compressed air. Compressed air will blow stuff everywhere in spite of gravity. I would get a large tub or tank that you can immerse the engine into. Fill it with diesel fuel and hang the block in it. You can slosh the block back and forth or get a paint stirer and get the fuel moving. As the residue washes off inside it will settle to the bottom. Raise the engine and lower it several times and then stir it again. That way the residue should all move only downward. Then save the tank for future parts washing or use the fuel for starting fires. I made a large tank out of an old Job Box I found cheap on Facebook. Get some of the tank sealer that Por 15 sells and seal the seams if its not watertight. Makes a really good cleaner and the diesel fuel lasts forever. Of course don't clean parts in the diesel fuel and then go into the house feeling amourous........... Oh, I put a flat steel plate in the bottom so I didn't have to worry about poking a hole in it.
No matter what you use, if the cam looks dry when you're done, I would wipe some cam lube on the lobes or at least some STP. Gary
Thanks for all the advise guys will try the brake cleaner outside the garage in the gravel...the grit was inside the oil pan on the bottom...I dont know how it got there,this looks like a low mile after rebuild
