Technical How to Identify a posi in a 9”
Discussion in 'The Hokey Ass Message Board' started by Cody49Ford, Jul 11, 2025.
  1. Cody49Ford
    Cody49Ford
    Hey all I’m looking to sell this 9” center section and the question is if it is posi or open. Is there anyway to tell from these photos? Thanks in advance all
    Boneyard51 and Tow Truck Tom like this.
  2. Flatrod17
    Flatrod17
    Stick your finger in the ring gear side and feel for a gap in the splines. If there is a break in the splines it a posi. The break in the splines you are feeling, the inner, the spider gear, the outer is the clutch pack hub. If no break in the splines it's a open rear.
    Just looking at it, I will guess its not a posi.
  3. Kerrynzl
    Kerrynzl
    That is an open diff !!
    Posi's have recessed crown wheel bolts
    Open have crown wheel bolts that are flush on the surface
  4. mohr hp
    mohr hp
    from Georgia
    FWIW, "Crown wheel" is Kiwi speak for "ring gear".
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ May as well be called a… IMG_4316.jpeg as well. ;)
    SS327, Boneyard51, swade41 and 2 others like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
  7. Rickybop
    Rickybop
    I seem to remember (very dicey concept) that when I ever turned the input shaft on an open differential, the wheels would turn opposite directions. And if it was limited slip they would both turn the same direction.
    Yes? No?
    Tow Truck Tom likes this.
  8. Budget36
    Budget36
    You’ll also want to know the gear ratio and the spline count for the axles, should be either 28 or 31.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    TECH TIP:
    A couple of splined stub ends from 28- and a 31-spline axles with a socket welded to the ends makes it easy for me to insert them into a pig and determine if if is 28-spline or 31-spline and whether it is posi, depending on if one shaft will easily rotate when the other is held still.
    I also use them in a vice to determine the slippage torque (as specified in the shop manual) needed to be exerted on the clutches when rebuilding the posi units.
    GuyW, Rickybop and BigRRR like this.
  10. saltflats
    saltflats
    from Missouri
    90 % of the 9 inch posi's I have taken out looked like that picture on the top. I think the ones in the Lincoln had a little more material in that area.
    Paulz likes this.
  11. mohr hp
    mohr hp
    from Georgia
    Everybody loves the 9" Ford, but most of them stock had really weak parts in them. And not a lot opted for Trac Loc.
  12. Cody49Ford
    Cody49Ford
  13. Cody49Ford
    Cody49Ford
    It’s a 31 spline thank you
    Budget36 likes this.
  14. Budget36
    Budget36
    I’d actually meant when you list it for sale. The gear ratio could also be attractive to someone.
    05snopro440 likes this.
  15. 05snopro440
    05snopro440
    Yep, when you list a center section describe what it is (gear ratio, posi/open, and spline count).
    That's one of my pet peeves, especially when it comes to people selling wheels and not listing the width and backspacing or offset, and sometimes even the diameter.
    Budget36, X-cpe and Algoma56 like this.
  16. X-cpe
    X-cpe
    Also bolt circle and stud count.
    Budget36 and 05snopro440 like this.
  17. 05snopro440
    05snopro440
    You're right, I forgot to mention that.
  18. Cody49Ford
    Cody49Ford
    Oh yes, for sure it’s listed with ratio and spline count . Those I could figure out haha, the posi part had me a little lost at first
  19. Cody49Ford
    Cody49Ford
    Yep I agree, had that part figured out.. the posi/open had me confused
  20. 05snopro440
    05snopro440
    Not an easy one to identify, spoken for GM guys like myself.
  21. True. My grandfather was a watchmaker. Went to the Bradley Horology Institute to learn the trade.
  22. Boneyard51
    Boneyard51
    That’s not a trac loc!
    Bones
