How Many 348/409 owners on the H.A.M.B.
Discussion in 'The Hokey Ass Message Board' started by BSL409, Jun 15, 2013.
  1. Last edited: Feb 12, 2014
  2. ruben solis
    ruben solis
    I just finished a 1958 belair Black on Red with a 409 /tech 5 transmission runs great.going to sell it at the round up in texas
  3. nostalgia62
    nostalgia62
    I've been layed off for over two years, but when I get my feet back on the ground, I plan on finishing my grandfathers car it's a 348/700R 60 Belair 2dr. sedan. Next project is a 409/5 speed Tremec 62 Belair bubbletop :)!!!
  4. Saubrenner
    Saubrenner
    We have a 63 Impala bench seat car with a 409 and 4 speed, it's been almost finished for 10 years. I have a 65 C-80 tractor with the original 409, 5 speed and air brakes, look for it at the American truck Historical Society show in Springfield this year. I also have a 65 Low Cab Forward C-60 grain truck with the original 348.
  5. BSL409
    BSL409
    How about some photos please:cool:
  6. jammer
    jammer
    Mines a 62 Biscayne 2dr. post ,Adobe Beige/Fawn , NOM 62 409/409 , 2x4, 4sp
  7. jrs9431
    jrs9431
    Any idea what he would want for a 409 / Any truck 409`s? thanks
  8. Terry O
    Terry O
  9. oldcars.acadia
    oldcars.acadia
    My 61 Biscayne 2 dr that I have had since 1985. 409, 4 spd
    Baumi likes this.
  10. Ringleader
    Ringleader
    Alliance Vendor
    My current W powered headache...hahaha
    neilswheels likes this.
  11. Ringleader, what kind of blower intake manifold is that or did you make it?
    Dustin
  12. '48IHC
    '48IHC
    Have a lead on a running 409 out of an impala.. Never been gone through but has even compression (although low) but even in every cylinder. What's it worth?
    Before anyone asks, the car was hit extremely hard in the rear and is full of rust on top of that. The owner parted what he could and crushed the rest.
  13. Ringleader
    Ringleader
    Alliance Vendor
    I made it... started life as a 2x4 set up and I went from there. I looked at available intakes and they were just too expensive.... now we'll just have to wait and see if mine holds up but I probably won't be throwing a ton of boost at it anyway. I've got a blown sbc that'll run circles around this blown W but I want the nostalgia cool factor and not a belly button sbc.
  14. BSL409
    BSL409
    I like your 55:cool: but that old 09 if setup right will run circles around that SBC you have:D
    countrytravler likes this.
  15. countrytravler
    countrytravler
  16. Mike Sherron
    Mike Sherron
    My 30 chevy with a 348 4spd
  17. Jefe1970
    Jefe1970
    I have a low mile 58 348 an PG out of a 58 wagon, 1 4bbl intake an 2 tri power intakes and a matched set of 64 425 carbs. 348 was mocked up in my 39 tudor but shelved the project. thinking about stroking it for a 56 Chevy
    neilswheels and loudbang like this.
  18. loudbang
    That is a BEAUTY. :) You have a build thread or more photos?
  19. Fitnessguy
    Fitnessguy
  20. models916
    models916
    Here is mine running frontage road
  21. JimSibley
    JimSibley
    Ron Funkhouser and loudbang like this.
  22. Fuelaltereds4life
    Fuelaltereds4life
    I'll throw my hat in the ring. Newly minted 409 owner... Can't beat the look of a Dual Quad 409!
    Sent from my SM-G920V using The H.A.M.B. mobile app
  23. coilover
    coilover
    from Texas
    A 37 Chev Business Coupe with a 503 (409 with 454 crank) and he also has a stock bore 409 62 with a blower and electronic fuel injection. He goes first class on his builds. The pretty valve covers had to go for clearance reasons.
  24. Mike Sherron
    Mike Sherron
    I’ll go through my camera and see if I can find my card with the build. I had a 49 ford and I traded it with my boss when I was 18. It was flat blue then. “30 now”
  25. uncleandy 65
    uncleandy 65
  26. saltflats
    saltflats
    from Missouri
    How did I miss this o_O
    Something about these engines that just suck you in. :)
    Max Gearhead and loudbang like this.
  27. models916
    models916
    Just a FYI for the 2x4 guys with progressive linkage…..Rear carb in the upper bushing hole, front carb in the lower drilled hole. Linkage is adjusted so both carbs are wide open at full throttle. Engine then runs on the front 2 barrels of the rear carb at idle and part throttle.
