Technical How I set toe-in
Discussion in 'The Hokey Ass Message Board' started by Andy, Aug 23, 2023.
  1. nutter_street_rodder
    from Nevis MN
    Cornwall Quality Products, Mogadore Ohio made this a long time ago. I got it at an auction for a service station closing ago toe_tool.jpg adj_end.jpg ut 40 years ago
    AHotRod, bobss396 and Johnny Gee like this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Is it complete? I guess you could flip it 180 to check the other side so long as there is a stop of sorts in that design that I’m not seeing.
  3. sunbeam
    sunbeam
    Looks like end with out the gauge has a clamp bolt to lock it
  4. We did them on the run with the stock cars, if the steering wheel was off, no biggie. I marked "center" on the wheel with tape anyway.
    It is however nice to see some old and conjured up tools that are at least fairly accurate.
    Driver50x likes this.
  5. blue 49
    blue 49
    from Iowa
    Looks like this tool checks off of the tire sidewalls.
    Gary
  6. s55mercury66
    s55mercury66
    from SW Wyoming
    Masonite plates with grease in between them, and some toe plates from the stock car days. Confirm steering wheel center with a string line to the rear wheels. Make certain your runout is not excessive, and be sure you have matching tape measures for the toe plates, some have a little more slop than others.
    bobss396 likes this.
  7. Driver50x
    Driver50x
    One thing that no one has mentioned. If you are measuring off the tire sidewalls, you should first jack it up, spin the tire, and find the “high point” of the sidewall. Put a mark on that spot. When you are measuring the toe put that spot either straight down or straight up. That will give you a more accurate measurement.
