Technical How do you test a GM 4 pin module
Discussion in 'The Hokey Ass Message Board' started by Bonehead II, Apr 12, 2016.
  1. Bonehead II
    Bonehead II
    Hey guys
    I have lost spark at my coil, went to NAPA got another module and the same thing, no spark
    So I'm wanting to know how to rest a 4 pin module.
    Thank
    Mike
  2. squirrel
  3. Take an ohmmeter and connect it to the white and green leads on the pickup coil and move the wires every way possible. I suspect you will find an intermittent open circuit in those as they are very commonly broken due to very fine and flexible wires.
  4. Agree with above. Have repaired 2 due to break in wire. Believe it's from the advance plate going through the motions, repeatedly.
  5. Truckedup
    Truckedup
    Before you plug in a new module check the coil for shorted winding. Supposedly defective coils are the cause of a lot fried modules.
  6. no55mad
    no55mad
    That unit puts out a hefty spark. Check the rotor. The metal strip on top of the rotor, that contacts the button from the coil above, just below that rotor metal strip, it will arc a hole through the rotor plastic and sending your spark directly to ground.
