how do you drill a hole in leaf spring
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, Aug 26, 2010.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    My question is how do you drill a hole in a leaf spring ,
  2. Mr48chev
    I think the spring shops punch them. I've never had much luck trying to drill through a spring during my attempts.
  3. why would you want to put a hole in a leaf spring?
  4. Checksix!
    Checksix!
    Just use a quality HSS bit and a little oil, don't spin the bit too quickly.
    Dave
  5. Checksix!
    Checksix!
    P.S., don't forget to debur with a C/S to help prevent cracks.
    Dave
  6. swissmike
    swissmike
    Use a die grinder with a carbide ball bit. I used it make the recess for a spring clamp with the locating dimple.
    If you need to drill through a stack of leafs I'd invest in a solid carbide drill bit. As mentioned, go slow and use cutting fluid.
  7. BOWTIE BROWN
    BOWTIE BROWN
    very carefully.
  8. noboD
    noboD
    In a drill press ONLY. It's no big deal.
  9. chicken
    chicken
    from Kansas
    Yep,drill press using low speed,a good sharp bit and good drilling/tapping oil and it will cut right through. I've done this many times and firm pressure and low bit speed are key.
    chicken
  10. Blacksmith54
    Blacksmith54
    from Phoenix AZ
    I use quater elliptic springs on my T buckets and I just use an end mill of what ever size i want it to be at about 640 rpms and cuts like butter also cobalt drills (the split point kind) do almost as good. And yes you want to deburr after.
  11. Commish
    Commish
    from NW Ok
    Drill press and a cheap masonry drill with the brazed on carbide, might need to touch it up a little on a green wheel. Use cutting oil and don't push it to hard, you can get it hot enough to melt the braze. If you know someone who has a Cole Drill you could drill it with a good HSS drill.
  12. 39 Ford
    39 Ford
    I had to put some holes in my bumper brackets,which are spring steel, ended up using a hot wrench (torch) to do the job.
    AugieP likes this.
  13. fab32
    fab32
    All of the key ingredients in one tidy post. +++++++++
    Frank
  14. model.A.keith
    model.A.keith
    I used a 'masonry' drill bit slow speed and plenty of oil, worked ok for me.
  15. Jonny69
    Jonny69
    from England
    I recommend Dormer or Hertel drills. They'll go through with a slow speed and plenty of cutting oil no problem.
  16. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Thanks Its just the bottom leafs The holes just dont line up with the plates .I know there tempered and I also know you dont want to use heat ,Im taking a break from the 29 and fixing another mistake on the 32 pickup ,
  17. Ruiner
    Ruiner
    Whoever said to use a plasma cutter should be slapped...HARD...
    I wish everyone had some basic machinist training to know just how important speeds and feeds are, not to mention cutting angles, lubricants and proper safety...it's good to see guys giving great advice, and even better to see people heeding that advice...
  18. Go to Lowes . In the tool department you can by a colbalt drill. Works great!
    Don
  19. Blue One
    Blue One
    from Alberta
  20. jcmarz
    jcmarz
    from Chino, Ca
    I've drilled a hole thru a 7 leaf spring and it wasn't hard to do. I have a drill press and I used a cobalt drill bit. Slow speed and lots of oil, it took me about a hour to do both leafs.
  21. geezerkat
    geezerkat
    Sloooow RPM----100 or so.
  22. Halfdozen
    Halfdozen
    Amen.
    Drills cut only on the cutting edges, not on the web or the sides. Learn to sharpen a drill properly by hand. Practice. Don't heat it up to the point where it changes colour, better to not quench it when sharpening if you can. Use a centre drill to locate the hole, drill a pilot hole for larger sizes. Deburr with a countersink.
    Speeds: General rule of thumb, four times the cutting speed of the material, divided by the diameter of the drill= drill press speed. Use 90 sfm cutting speed for steel, 200 sfm for aluminum. Tougher steels- divide by two, carbide tooling- multiply by 2-4. This'll get you in the ballpark.
    Edit: Coolant is a must. Water-soluble coolant/ cutting oil mixed about 20:1 is best, light oil is ok too. Keep some in a squirt bottle by the drill press, use liberally.
  23. vendetta
    vendetta
    as per what everyone else is saying-drill press/cutting fluid etc.either an end mill or drill bit.if you are after a 1/2" hole i'd start smaller-say 1/4-3/8 first so the hole doesn't "walk" on you.
  24. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Thanks my drill press is already set at the lowest setting ,I was gonna heat it up first ,But I heard that would take the temper out of the spring and drilling it with a drill I didnt think would work ,But like always You guys would know ,
  25. need louvers ?
    need louvers ?
    I'm going to say what everybody else has, but throw in a twist! Then everyone else can tell me it doesn't work!!! Slow speed on the drill press, good quality drill, Instead of cutting/cooling oil? White glue! Yes, god old Elmer's white glue! A good buddy of mine hipped me to this about 15 years ago. He was a hot rodder emeritus, racer, and grew up in his family's heavy truck repair business. I usually took evrything that Larry said at face value and never questioned it, but this kinda made me say; "Huh?" Then he proved it! It's the only way I have done it since. The other cool thing about this, is the quality of the drill bit doesn't seem to matter as much as it would with regular cutting oil. Try it and tell me I'm wrong! I've done it lots, by the way...
  26. spinman
    spinman
    from new jersey
    I went thru a bunch o' bits doin this for my bike front end. The bits started out good but then pooped out about 3/4 thru. guess they heated up and hardened the alreday hardened steel.
    Spin
  27. spinman
    spinman
    from new jersey
  28. dragster dude
    dragster dude
    cant agree more it seems that because you can now buy tools at afordable prices thatplasma has become todays oxy equivelent unfortunatly educated knoledge seems to be in short supply . thank god for the hamb
  29. dragster dude
    dragster dude
    dont heat!!!!!!
  30. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Thats why Im not heating ,Ive already drilled my spindles cost 30 dollars in bits .Heres the real kick in the pants ,Needed drop spindles anyway .Anyway back to the leafs ,Thanks Its what I thought
