Technical How do you dispose of used antifreeze?
Discussion in 'The Hokey Ass Message Board' started by atch, Apr 27, 2024.
  1. Dooley
    Dooley
    from Buffalo NY
    Local oil change place...after hours
  2. 49ratfink
    49ratfink
    I pour it down the sewer so it goes into the San Francisco Bay and makes the fish glow at night.....
    actually I don't think I've ever drained a radiator that had much more than rusty water in it, if it is still green I just leave it.
  3. Sharpone
    Sharpone
    Ethylene glycol is biodegradable, breaks down in 10 days or so. That being said spreading on the ground may pose a risk to pets or wildlife, many places will accept antifreeze for recycling, municipal dumps and some auto parts stores take it for disposal for free. There is some debate on whether it can or should be poured in a municipal sewer system, call your local waste water treatment facility for clarification.
    Dan
    Tow Truck Tom and Ned Ludd like this.
  4. SS327
    SS327
    The solution to pollution is dilution!
    49ratfink, Sharpone and clem like this.
  5. moparboy440
    moparboy440
    from Finland
    The same way as oil:
  6. G-son
    G-son
    from Sweden
    The buildup of that green crap (that also plugged the core of this small aluminum radiator) and the severe metal corrosion hiding under it disagrees with you.
    Coolant contains additives to prevent corrosion, once those additives run out things can really go bad - and expensive. upload_2024-4-28_11-23-17.jpeg upload_2024-4-28_11-23-39.jpeg
  7. For those folks in & around the North/Central Ohio area, there is a company located in Mount Gilead, Ohio that recycles it into new somehow. They used to be closer to me & would come pick it up if you had a tank. I took about 25 gallons down to them that I had built up a couple of years ago. No charge other than the time & fuel to go down there. (sorry name escapes me, but a search can find it I am sure)
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
  8. :eek::eek::eek:
    Sharpone and Bill's Auto Works like this.
  9. I cannot find anyway of disposing of it. Right now I’m storing about five gallons. I’ve tried everything and everyone listed. I’ll keep looking.
  10. Some shops have recyclers.
    Like they do with waste solvents and refrigerants.
    SS327, Sharpone and Truckdoctor Andy like this.
  11. Driver50x
    Driver50x
    Ethylene glycol completely breaks down within 10 to 28 days. Depending on which source you believe. For what it’s worth, airports dump tons of it on the ground when they are de icing planes.
  12. atch
    atch
    The hospital I worked at for most of my adult life had an industrial hygienist on staff. I said that to her one time and she 'bout had a coronary.
    Truckdoctor Andy, Sharpone and SS327 like this.
  13. error404
    error404
    from CA
    I let it evaporate in plastic storage bins (what I use to catch the coolant when draining). I have a lid with holes in it so animals can't get in. takes a while, but it doesn't take any of MY time.
    winr, SS327 and Sharpone like this.
  14. justpassinthru
    justpassinthru
    The easy way:
    Drain on the driveway and wash down the sewer, which I don't do.
    The hard way:
    Have the cheep piece of crap radiator cap blow off the radiator while overheating in your face, and then wash down the sewer.
    That happened to me Wednesday.
    Bill
  15. I strongly suggest that you put used coolant back into coolant jugs and take it to your household hazardous waste facility and/or check if local auto parts stores accept it.
    https://www.stancounty.com/er/hazmat/household-hazardous-waste.shtm
    jimmy six, nochop and Sharpone like this.
  16. You shouldn't dump or flush new or used antifreeze/coolant. It's usually not pure ethylene (or propylene) glycol when new, and it's likely contaminated when used.
    gimpyshotrods, Sharpone and Ned Ludd like this.
  17. Sharpone likes this.
  18. Ned Ludd
    Ned Ludd
    By contrast propylene glycol is edible, and is an actual approved food additive. All that other stuff isn't, though.
    gimpyshotrods, SS327 and Sharpone like this.
  19. Ned Ludd
    Ned Ludd
    Some pollutants break down naturally, some don't. Some break down to harmless substances; some break down to nasty stuff.
    The pollutants intended to be controlled by a catalytic converter are all substances which break down to harmless substances, given enough time. The component with the longest half-life is, surprisingly, the CO. It follows that there is a rate of generation at which a substance gets replenished faster than it can break down. The purpose of smog equipment was to allow that rate of generation to keep being exceeded.
  20. dirt car
    dirt car
    from nebraska
    Early on I called our city services & they said to dispose of it down the sewer system, however since I was on a septic system I was unsure how it would affect the workings so consulted a local drop off site for used chemicals, oil etc.
  21. Sharpone likes this.
  22. dirt car
    dirt car
    from nebraska
    Not certain what the collection sites might do with anti-freeze they may well use the sewer system anyway, seems we have little or no means to dispose or recycle the products we produce, I was of the opinion that anti-freeze never wears out only weakens & becomes acidic, but may be cost prohibitive to remanufacture.
  23. Donate it at your local used car lot
  24. In_The_Pink
    In_The_Pink
  25. Beanscoot
    Beanscoot
    A few years ago an acquaintance invested in a facility not far from me that recycled antifreeze, they vacuum distilled it, then added the appropriate additives and dyes. It was then sold to local car dealerships' service departments.
    He gave me a couple gallons for my fleet.
    I imagine there was a small, continuous stream of hazardous material (dregs) that they had to ship out, but I didn't get all the details of the refining process.
  26. Budget36
    Budget36
    I wasn’t going to belabor the point, but did do some math:)
    So the small septic tank that was put in for the shop was a 1500 gallon tank.
    A septic tank comes divided. 1/2 “dirty” water which it sees when it’s in use first. There’s a cut out in the divider that leeches liquid over to the “grey” water side that when full, dribbles out the leech line.
    Okay-too much info.
    So say I dumped 2 gallons straight AF in the toilet. It would mix with roughly 750 gallons of black water the leech over and mix with roughly 750 gallons of grey water.
    2/750 is (rounded up) .003%. 1/2 that if 50/50 mix. , not even taking into account the grey water side.
    Sharpone and Desoto291Hemi like this.
  27. SS327
    SS327
    Propylene glycol is what they use to de-ice airplanes. It makes a great fertilizer too.
  28. lemondana
    lemondana
    from Lincoln NE
    Leave it in pans for the roaming tomcats.
    choffman41 likes this.
  29. spanners
    spanners
    Am I glad we don't have to use antifreeze Downunder. We do have a recycling facility for politicians. It's called government.
  30. Gastrap
    Gastrap
    Pour it in the used coolant tote at work, a recycler pumps it out a couple times a year. They get a LOT of 15W40 in that tote from various types of engine failures.
    Truckdoctor Andy likes this.
