I'm getting ready to mock up my 33. I'd like to see some side shots of 32 to 34 pick ups with different bed lengths. Thanks!
here is same box shortened a lot....can't remeber how much I took off the back of box sides. I tried to equal out the space ahead of and behind fender.
this pic may not be of much help but this too is the shortened 32 box. You can get an idea of the difference roof height makes on profile. The great hamb photochoppers helped me out a little on this one a while back. Steve
First pic of my truck mocked up -- stock '34 cab & bed, full fenders, lowering complete, final wheel & tires selected -- I thought the proportions were good.
This is the truck that inspired mine: '32 cab, model A bed and rear fenders, stacks -- but now that mine is done, I'm glad it's more nearly stock. The A bed looks too small to me now with a stock-height cab.
My box was shortened by just cutting the end off it (by some dimwit before I owned it), I took it apart, swapped sides, then added some metal at the front to get the wheel more or less in the middle of the wheel belt line, then put the bed stakes where they're supposed to be.
Christian, I can't remember if I've seen your truck before -- if so, it was a long time ago. That is one CRAZY bend in the frame!
Ive found an AA truck box for my A RPU, does anyone know if they were bigger/wider than a normal pickup box? will probably shorten it so length isnt important.
