Homemade Wishbones
Discussion in 'The Hokey Ass Message Board' started by CRH, Dec 25, 2009.
  1. CRH
    CRH
    from Utah
    This is the cut off piece from the middle.
    Since I've been listening to OCD instead of sound judgment, I decided to try making rear split wishbones. The pipe I used was 1-1/2" that I squashed in my cheapo Harbor Freight press, back and forth, over and over. I then chopped out the angle, hammered off the dross and welded up these homemade wishbones. Was it worth it? Well, I realized once again that metal likes to bend, warp, and flex when you get it hot!! And my welds kept turning out porous unless I went to the old stick welder with DC 7018.
    Oh, and I made the taper too soon, so the bungs I wanted to use for the rod ends won't fit as well as I originally "planned for." Cool experiment, but now I think I'll bite the bullet and buy a set of '36 rear 'bones from steeljunkiesII. Oh well, it was a learning experience!
  2. Ole don
    Ole don
    That is really neat work. I did a set of splits on the roadster I built, here is what I found. The 36 front bones were .156 wall. Nice and solid. The rears were made from 39 bones, they were much thinner, and I dont remember what the figure was. It was an odd number, like .129? If I were to use them on a late model V8 powered car, I would drill 3/8 holes every six inches along the bottom, and rosette weld anther tube inside for strength. The forged end that bolts to the axle is good metal, I heated and bent it, then boxed it. No problems with the flathead.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    A friend extended his dogleg bones which had been cut off short by a previous owner by this method. Works great and looks good too.
  4. hotrod56cars
    hotrod56cars
    Looks good from here CRH.
  5. backn62
    backn62
    Has anyone ever put a vega box on a 46 ford pickup with all original suspension? HELP
  6. CRH
    CRH
    from Utah
    Ole Don- thanks for the idea...I actually wanted to use Model A rear 'bones, but they are mighty dangerous. I wonder if I could reinforce them with some strong small tubes inside?
