HF bead roller reinforcement?
Discussion in 'The Hokey Ass Message Board' started by Bumpstick, Feb 25, 2006.
  1. Bumpstick
    Bumpstick
    O.K. I did check the tech dept. first but couldn't find any info. Just picked up a bead roller at Harbor Freight (they're 99.00 right now) and I recall threads about reinforcing with gussets to keep it from flexing. Where should I weld 'em and how many? Got any pics of yours? Thanks all. -stick
  2. http://www.metalshapers.org/101/bead-roller-mods/
  3. chrisntx
    chrisntx
    from Texas .
    Very Good. Now will someone please show us how a Fence is designed? I want straight beads!
  4. TINGLER
    TINGLER
    That Metalshapers method seems to go the long way around the block.
    Someone on here posted a pic of the one they did and I thought it looked simple and nice.
    They built a "C" shape out of some tubing (maybe 2"x2") with tabs welded to it. Then they simply drilled some holes into the body of the bead roller and bolted it to the big "C" structure.
    BTW, I've used mine for a while without any sort of support. It does flex. but unless you are building something that needs to be perfect, I wouldn't think it matters that much.
    The steering wheel modification is a MUST however. That is what I would (and did do) first.
    Hope this info helps.
  5. tisdelski
    tisdelski
    hi guys,
    heres a pic of my hf beadroller beefed with 2x2. i was going to put a steering wheel on it but just bought a gearmotor and controller to power it instead. i would recommend highly to beef it up.
    gary
  6. ray
    ray
    i did mine similar to that, only i used 1 1/2 angle iron, with the open part of the angle to the plate of the bear roller. i tried it once without the reinforcement, i don't know how anybody could use it like that, now you can do beads in one or two passes.
    also did the steering wheel, i was a little concerned that the wheel was smaller than the hand crank and i wouldn't be able to get enough leverage, but found it was no problem, with the wheel you can kind of lean your arm on the wheel and get a nice smooth action with little effort.
    i also polished the HF rolls in the lathe, they were pretty rough, i didn't want that roughness transferred into the workpiece.
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    The 2X2 steel channel isn't a bad way to go, unless you have some
    extra steel plate layin around, than I'd go with that. Replace the
    chicken shit allen screws, on the rollers themselves, before they
    strip out. Also, replace those square headed shaft pressure bolts
    with threded stock bent at a ninty, so you can set the pressure
    on the fly, without having to reach for an end wrench.
    For a guide,I have always just vise-gripped a piece of angle (although
    I bought the factory guide) to the frame, and set the depth as neces-
    sary.
    Swankey Devils C.C.
  8. 52pickup
    52pickup
    from Tucson, Az
    Here are some picks of my bead roller. It has much less flex than it did before... but could be better. It can do 18ga steel full depth in one pass. Reinforcement is 2x2x.250" angle
    the stripes help make it stiffer too :rolleyes: :D
  9. Bumpstick
    Bumpstick
    Thanks fellas now I get it. 52 Pickup, the stripes are a nice touch. -stick
  10. ckdesigns
    ckdesigns
    from Ogden,Utah
    I have yet to reinforce mine but when I did use it the depth of the beads or flanges would change. It seems that the shafts are to small for the dies.
    Am I crazy or does anyone else have the same problem.
  11. ray
    ray
    52pickup, you should have something connecting the angle iron parts at the crank end of the roller, it will make a ton of difference! also, nothing wrong with the way you did it, but angle iron will be stronger there if it formed a closed triangle to the plate, not with one flat to the plate.
  12. alittle1
    alittle1
    Anyone have any pictures of stands for the above, or other reinforcement ideas??
  13. 52pickup
    52pickup
    from Tucson, Az
    yea i know , and i was thinking that when i did it. I probably will one of these days... but will probably wait untill i setup an electric drive for it.
  14. rattlecanrods
    rattlecanrods
    Here is how I did it... works good so far. Need to mount it and add paint...
    BTW: Does anyone have a good way to make a tipping die without a lathe?
  15. sawzall
    sawzall
    i have posted this before.. my workcenter.. the yellow portion is the bead roller, and it of course is a hf unit.. its welded in position.. the "gussets" are 1x1 square stock.. nothing fancy.. strictly utilitarian.. no power.. YET..
    the entire machine weights around 700 lbs..
  16. 52pickup
    52pickup
    from Tucson, Az
  17. One of the biggest things after the reinf. , drill & retap all the chink butter set screws with American Allen set screws. Reinforced right it'll roll beads in 16ga steel single pass.
  18. rattlecanrods
    rattlecanrods
  19. mark8040
    mark8040
    from Fort Worth
    Here's a couple I took of mine. I put a gearmotor I bought off of ebay on it. 20 gauge is about all I run through it.
  20. michael037
    michael037
    I have set mine up similar to 52pickup, only I have the flange of the 2"x1/4" angle the other way (in other words closer to the jaws of the throat of the machine). One thing I was wary of was welding the angle to the frame, so I used 5 3/8" bolts along the top and the bottom. Also tied the top and bottom angles together at the drive end with another piece of the angle, and a piece of heavy wall square tube, that I hope to be able to put a mounting plate on for a geared motor.
    Don't have a camera, so can't post any pics.
    Michael
  21. Rickdeluxe
    Rickdeluxe
    Here's mine, it feels sturdy. Haven't tried it, really...
    I put in on a piece of pipe with a single wheel at the bottom and hinged it on the table that has my mill on it. That way I can swing it outtatheway when not in use.
    Pics on my website:
    http://www.hotrods.nl/werkplaats/Desktop.html
  22. lodaddyo
    lodaddyo
  23. Ruiner
    Ruiner
    well, I guess it looks like I won't need to do a tech article on how I did mine then...looks like everyone's pretty much got it together...good pics guys...I'll post pics of mine if I ever get another digital camera
  24. I got the same thing, but notice the dies dont spin evenly...like up and down, creating a poor uneven bead...I think its the stupid set screw holding them down.
    Anyone have this issue?
  25. What is a tipping die for?
  26. ray
    ray
    for "tipping" a flange, for example on an curved part where a sheetmetal brake won't work.
  27. pimpin paint
    pimpin paint
    from so cal
    Yeah Norm, it sounds like the set screws are fuckin ya over. Replace with
    ''real'' steel ones.
    Swankey Devils C.C.
  28. Flipper
    Flipper
    from Kentucky
    Anybody got "in process" pictures of how tipping works?
  29. zman
    zman
    from Garner, NC
    Just FYI, I've been seeing a bunch of free treadmills on craigslist these past couple days. The motors and controllers from those would be perfect to motorize one of these...
  30. Paul
    Paul
    Editor
    surplus tread mills?
    all those people musta got skinny and don't need em any more!
    as for bead rollers on the HAMB
    NealinCA has it hands down
    saved in the Tech Archives, here's the link
    Another HF Bead Roller Stand...
