Hemi Question
Discussion in 'The Hokey Ass Message Board' started by gsp392, Nov 13, 2010.
  1. gsp392
    gsp392
    I think my dads old 354 poly block might be in my grandfathers shop somewhere. I have an extra pair of 331 heads. If I can find the block I might put 'em together and make a display engine. If I ever wanted to, would this combo work for a running enigine? I know 354 Hemi heads work on a 354 poly block, but would 331's?
  2. 23reotim
    23reotim
    from arizona
  3. tad626
    tad626
    331 and 354 heads are interchangable. I believe 392's are also, but, due to a higher block, they might need masaging.
    Art
  4. George
    George
    392 heads don't really, not worth the effort. Plenty of info on the hemi tech index on converting a 331/354 Poly to hemi.
  5. gsp392
    gsp392
    As long as it'l work I'm happy :) I'll make another display engine for my shop.
  6. George
    George
    You can bolt the 392 heads on, but the intake & the 354 W/P (or 392 water crossover) wont fit.
  7. 73RR
    73RR
    ...and depending on which 331 heads are used, some additional problems occur.
  8. George
    George
    354 truck heads for that matter....
  9. gsp392
    gsp392
    I don't intend on doing anything with this combo other than painting it and bolting everything together. This is like the bonus Hemi that I didn't know I had. As long as I can find the block.
  10. George
    George
    If you have the front opening '55 331 heads, no problem. If you have solid front heads(51-4, or truck) you can assemble a nice looking display engine w/o any way of getting water out of it to the radiator(w/o modding a few things).
  11. gsp392
    gsp392
    These are solid ended heads a friend gave me a few years ago. I figured they would be better sitting on the block where I can look at them instead of on the shelf.
  12. George
    George
    If you decide to run it that way, there's info in the Hemi Tech Index. If it has round, instead of oval ex ports, you'd probably want different heads.
  13. gsp392
    gsp392
    It does have round ports. I'll try to get the casting numbers off them next weekend. I doubt I'll ever run this one.
  14. George
    George
    No need, they're the early 51-3 heads. '54 & up are better heads. Still look good on a stand!:)
  15. gsp392
    gsp392
    Well I won't be using these 331 heads on the 354 poly block after all.
