Looking for advice for wheels for my 41 Ford deluxe. It's dropped with a axle and reverse eye springs. I have disc brakes on it so I gained width. Right now I'm running a 60's Studebaker 15x4.5, but I'd like some options. The rim is 3 1/8 backspacing, with 1 3/4 from front of rim to wheel mount surface. I am looking at front drive wheels, but most are not appealing. I think I could go wider with the rim inside the car, but no further outboard. I have 185/65/15 tires on it. Thanks for the help. Sent from my LM-V405 using The H.A.M.B. mobile app
Quick and easy is to collect a few sets of hub caps then you can change the look as often as you like.
