Ok my daughter is puttin together a mini bike to have fun with. I have an old pressure washer with a motor made from tecumseh model ohh50...its not idiling and i dont know if it suppose to. if so how do i fix it?? please help me out with this is for my daughter thanks!
Most of the pressure washer engines run at their operating RPM. You will have to do some rework on the governor to get an idle and throttle usage. Check where the off switch is at, the governor assembly is usually there.
