I have a tri power intake trying to find base for the end carbs All I see is small base for sale Thanks
I am guessing that you want to convert the end carbs to dumpers without idle circuits? And you are looking for carb bases that are so configured? That's one way. You could also modify the bases that you have to block off the idle and transfer functions. In either case the important issue is sealing the throttle blades. That's best done with the thicker blades and some fitting. Lots of info out there about doing it.
