I pulled this from my 37 Plymouth, and was wondering if anyone could help identify it's year/size/details. Thanks Motor Serial Motor Date Old Motor Trans ID
Hi. My book with numbers is with my car and it is in the shop awaiting a few parts to come in for repair. Basically that would be the same engine in my 50 Plymouth deluxe. Mine is a 217.8 CI engine. There are two different length engines in the flathead 6 series, a 23" & a 25" length. Not positive where they measure but likely head length? I think the Chrysler & DeSoto were the longer version and may have a bit larger CI displacement. I have found several places that have a fair amount of new old stock as well as aftermarket parts & stuff for these models if you need them let me know. I got my Plymouth at a good deal recently as it was running like a piece of shit & missing & shaking something fierce. Body & interior is excellent with an older paint and interior redo. Checking out the engine when I got it home they had 2 plug wires reversed and it purrs like a kitten now. I did find out that on my engine there were 3 different distributors used in 1950 alone and to get a cap & or rotor you MUST have the # off the distributor tag. Check this out if you want to hop it up a bit - very interesting site - https://www.moparmontana.com/ . Also check out Cliffords for cams & intake manifolds with multiple carbs - https://www.cliffordperformance.net/ I also have a few other links for the Plymouth hop up stuff. Plymouth flat head hop up stuff is expensive. Also here is the link to Plymouth Owners Club magazine and they have tech advisors & a forum. http://www.plymouthbulletin.com/ Jimmie
ID number looks to be T306 which would be a 51-53 218 from a truck. Here is more info http://www.t137.com/registry/help/otherengines/tengines.html Sent from my SM-G950U using The H.A.M.B. mobile app
