Hello Fellow H.A.M.B's I have a 54 Customline (Ford) and have been trying to find out how the hell you take off the door handle and key on this thing. I am planning on shaving the doors but can't figure out how unless I have to cut them out. Any Help would be appreciated.
It's been a long time since I removed mine but I do know you have to remove the inner door panel to gain access to the screws holding the handle. HRP
You are correct,access to this screw is under the weather strip on the inside of the edge of the door. HRP
2 screws accessable from inside with door card removed. The lock cylinder is held in place with a spring steel sheet metal retainer that is under the rubber weatherstrip at lock level.
