Projects Help Reading Y Block Spark Plug
Discussion in 'The Hokey Ass Message Board' started by AldeanFan, Dec 8, 2021.
  1. AldeanFan
    AldeanFan
    Carburetor tuning is new to me so forgive me for asking basic questions.
    I pulled a plug on my 292 powered Country Squire and this is what I’ve got.
    This is after about 5000 miles on new plugs with a new Holley 4010, same as summit carburetor.
    Car runs excellent but from the look of the plugs it needs some tuning,
    Where do I start?
  2. squirrel
    you might make sure the choke is working properly, and then play with the idle mixture...which might be a tad rich. Also, let us know when you pulled the plug out--what had the engine been doing the previous 15 minutes?
    When you adjust the idle mixture you want it as lean as it can be but still idle well, not hesitate when accelerating, and not quit running. Usually, this means that you lean it out until the idle speed starts to slow down, and then go back just a tad richer.
    Make sure both screws are adjusted the same number of turns as each other.
    GordonC likes this.
  3. AldeanFan
    AldeanFan
    Thanks!
    The car had been idling in the driveway for about 20min before moving it back in to the garage.
    It’s a mechanical choke so I don’t expect that to be a problem
  4. squirrel
    Sitting idling for 20 minutes, I'd expect the plug to look like that....maybe you should take the car for a long drive, then see how the plugs look?
    But it's a good idea to play with the idle mixture (and idle speed), so you can get it set up to idle and run just right. You can read about doing it, but still you have to get in there and do it, and see what happens, several times, to get it just right.
    Irish Mike likes this.
  5. jimmy six
    jimmy six
    Adjust with a vacuum gauge… my 292 plugs never look like that in the 10 yrs I’ve had mine; in fact because the fuel today they are very light in color and no soot in the exhaust either.
    I’ve done many 20 minute warm ups in my garage after repairs or installations (AC etc) and never a load up or black.
  6. Truck64
    Truck64
    from Ioway
    It doesn't take much extra fuel to foul spark plugs badly if any of the different carburetor circuits are out of adjustment or defective. To get an accurate plug read on color takes some experience to know what you're really looking at.
    Tuners use a technique called a "plug chop", by driving at a steady speed on the highway for a while and kill the ignition and coast to a convenient spot to pull over and inspect a plug or two. Fluffy black deposits on the "base ring" means jetting is too rich. The ground strap provides a lot of information on heat range and ignition timing.
    I would say you need to back up a bit and start with the stock heat range spark plugs ( if they aren't). Oftentimes people look to install "hot" plugs to try and compensate for a carburetor that is way out of adjustment. Check fuel pump pressure output & carburetor float height/fuel height carefully. That's the baseline for the entire carburetor. Power valve # needs to be selected for your particular engine & altitude. If the wrong # for your setup is installed or it becomes defective it will be pig rich.
    egads likes this.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You said new. But didn't the early 4010's have a bad rap due to cheap floats?
  8. 6sally6
    6sally6
    It is said............you really can't get a 'real' read on spark plugs unless you do a plug chop. Once it idles....goes slow...goes fast...goes 5000 miles....trying to 'read' them is useless.
    So forget that!
    Warm it up
    Plug the vacuum lines going to the carb
    Turn adjustment screws in until the idle 'just starts' to change sound(you can hear it)
    Turn " " out " " " " " " " "
    Turn " " 1/2 way between
    Just use a vacuum gauge and screw 'em until you get the highest reading!
    Make sure air filter is CLEAN.
    Advance distrb. 5 degrees.(Use a timing light... cheap one...not the dial back because they are NOT accurate)
    Keep advancing the timing until it rattles when going up a hill (or is hard to crank when engine is warm)
    Then turn the distrib back a few degrees until its gone.
    There's your tune-up pal !!!
    6sally6
  9. TA DAD
    TA DAD
    from NC
    The one you show looks like it has a lot of deposits on it ? from what I can see of the porcelain it looks like you have some detonation going on. I would screw a new set in and start fresh. And maybe buy some better gas.
  10. Truckedup
    Truckedup
    Tuning like this will generally work ok... but on some engines that are resistant to detonation, the timing can be advanced enough to reduce power and not ping..
    squirrel likes this.
  11. AldeanFan
    AldeanFan
    I can probably do a plug chop on my own street, it’s 3 miles from the end of the road to my driveway with no stop signs between and a 50mph speed limit, so I can make a few laps of the country block, shut her down and coast to my house and right in to the driveway.
    Unfortunately it’s snowing now so this will have to wait!
  12. Truck64
    Truck64
    from Ioway
    When I first got my Y-Block I didn't understand too much about Tune-Ups other than throw parts at it, and nothing about the finer points of plug reading. Plugs were coal black and dripping wet with fuel. Like everybody else at that stage I skipped 3 or 4 pages of Tune-Up instructions and figured a nice new shiny carburetor would fix that. It didn't.
    Before getting really serious about carburetor tuning and jetting and all that there are quite a frw other things to look at first, make sure the ignition is plussed up, with a good fat hot spark. Good clean tight low resistance grounds and connections, charging system, cap & rotor. Make certain there are absolutely no vacuum leaks, and the ignition timing advance is correct for all RPM levels.
    Try to use Holley or Autolite power valves, I'm finding that the generic no name valves that come in the cheap kits don't seem to last very long in today's gasoline. Maybe a year or two. When you get a sharp tune going you'll be able to tell when the power valve is shot right away, and the plugs will foul badly.
    I learned a lot looking at a vacuum gauge needle driving around town and on the highway. What you're doing ultimately is tuning each individual carb circuit independently, or "curving" the fuel mix for your engine.
    A lot of people will say that because of today's gasoline a carburetor needs to be jetted up. I'm not persuaded that is true at all, because carburetors in general are way, way rich right out of the box. In any case ya gotta give the engine what it wants, not what you think it should want, or what your other brother Daryl did with his engine.
    The plugs will tell you, they don't lie. Should idle crisply with steady 19" to 21" manifold vacuum and maybe 15" or so just cruising down the highway. A 6.5 or 7.5 power valve should be about right, but before you can decide on jetting see to it that the power valve isn't dribbling fuel on flat ground cruising. Jetting is the first thing you want to look at, but the power valve has to be out of the equation if that makes sense.
    Irish Mike and Truckdoctor Andy like this.
  13. AldeanFan
    AldeanFan
    Thanks everyone, keep the great advise coming!
    I really appreciate you guys helping out a guy just starting out
    Truck64 likes this.
  14. Truck64
    Truck64
    from Ioway
  15. AldeanFan
    AldeanFan
    unfortunately no update on this,
    I took the power steering apart to replace the seals in the ram but had the wrong ones, the correct seals were hard to find and just arrived today so the car has been in stands for a while.
    Truck64 likes this.
  16. Truck64
    Truck64
    from Ioway
    Well, OK... Get your happy-&@s out there! (Kidding)
