Projects Help me save/fix this ‘54 Chevy chop
Discussion in 'The Hokey Ass Message Board' started by punkabilly1306, Nov 18, 2017.
  1. punkabilly1306
    punkabilly1306
    from ohio
    Update: I got the car free from the frame and now I’m extra thankful I have the spare body. Because this thing is cobbled together and my spare body is now going to be my main body. [​IMG]
  2. Wow that sucks!!!
    Bondo and flatblack paint are like tequila and last call at the bar ....... they make everything look decent !!
    Keep going seems like you have a good plan to get this car sorted !!
  3. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    It's better than having no body.
  4. flamedabone
    flamedabone
    No need to chop that little Pontiac, in my opinion. Get her running, drive it for a while, then decide if it is worth the effort to chop it.
    It sucks to have to ditch the Chevvie body, but that thing was rough...
    Good luck, -Abone.
  5. punkabilly1306
    punkabilly1306
    from ohio
    Goal is to have it running/driving by spring with the frame work done. Cruise it for a bit then chop...I’ve always wanted a chopped ‘54 Chevy ...so chop it is [emoji3]
    Peanut 1959 and VANDENPLAS like this.
  6. punkabilly1306
    punkabilly1306
    from ohio
    The bad work on the Chevy just kept going and going.
  7. punkabilly1306
    punkabilly1306
    from ohio
    Trying to take what’s decent about the Chevy so I can start making it work on the poncho donor body 56021611696__39C3F16C-E28D-4FA7-845B-0E9F1B482138.JPG [​IMG]
  8. punkabilly1306
    punkabilly1306
    from ohio
    ...should I start a build thread page, or just keep going on this thread? [​IMG]
    VANDENPLAS and cretin like this.
  9. ROADSTER1927
    ROADSTER1927
    This thread will be fine for your build. Do not mention your engine stuff and you will be golden!:D Gary
  10. cretin
    cretin
    I say just make this your build thread.
  11. junkman8888
    junkman8888
    Back in '49, Pontiac and Oldsmobile began using a much stronger "C" channel frame while Chevy soldiered on with the "hat section" frame designed in the '30's, the frame change also means the body mounts changed, in other words, the Pontiac tub won't bolt up to the Chevy frame. Sorry.
  12. punkabilly1306
    punkabilly1306
    from ohio
    So I have to relocate the body mounts...? I can't imagine that will be that big of an ordeal, unless I'm terribly mistaken.
  13. punkabilly1306
    punkabilly1306
    from ohio
    Has anyone ever relocated floor supports/body mounts to put a body on a frame that it wasn't intended for? What are some tips/tricks that I should know?
  14. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Make a new floor, using a bead roller. If you don't want the hassle of making the mounts, just plug weld 1 x 2" tubing to the floor for supports, and cut 2 x 3", 1/8" wall tube at a 45* angle for frame mounts.
  15. punkabilly1306
    punkabilly1306
    from ohio
    Thanks! I think I can salvage most of the floor supports from the '54 chevy and then use them on the poncho body, but how do I know everything is in the right place, square, and how it should be? Measure, measure, and measure some more, but are there any hints/tricks to use when doing something like this?
  16. banditomerc
    banditomerc
    I admire your perseverance. Plenty of sound advice on this site make sure you use it. you're on the road traveled by many. don't lose sight of your dream and that will carry you through to the end
    Sent from my SM-J727T using The H.A.M.B. mobile app
  17. junkman8888
    junkman8888
    Not only are the body mounts an issue but most of those years vehicles are titled from the serial number plate mounted to the driver's windshield post. In other words, changing the body changes the title.
  18. cretin
    cretin
    How’s the project coming?
  19. 57JoeFoMoPar
    57JoeFoMoPar
    It's a lot easier to fix floors and rockers than undo the roof on that Chevy. I'd get the Poncho body mounted and start fixing the rot. Once the body is rust free and structurally sound, then move onto the chop.
    RMONTY likes this.
  20. punkabilly1306
    punkabilly1306
    from ohio
    Just to give an update, I found a super solid ‘53 Chevy only 20 miles from...stored in a barn for 20+ years and was being saved for a gasser project, but he knew he’d never get to it. I struck a deal to where I would only buy the shell and help him sell the rest...but now I’m debating on c-notching the rear and bagging it while the car is off the frame.
    VANDENPLAS and James D like this.
  21. ROADSTER1927
    ROADSTER1927
    Good for you! I am glad you are progressing. Gary:):)
  22. evintho
    evintho
    I like it! More pics!
  23. punkabilly1306
    punkabilly1306
    from ohio
    I scored some ‘54 fender flares off of a buddy of mine and started mocking those up today. I still need to make some end pieces so they taper back into the Chevy fenders. I still need to finish welding and finessing everything but I like the looks so far. [​IMG][​IMG]
  24. COCONUTS
    COCONUTS
    Forget about chopping the Pontiac roof and just channel the body over the frame, you are just about there now.
  25. punkabilly1306
    punkabilly1306
    from ohio
    Got the motor and trans mounted and headers set in place. So far clearance is all good. Going to notch the rear next and then 4 link to get ready for the new suspension. [​IMG][​IMG]
    VANDENPLAS likes this.
  26. Gman0046
    Gman0046
    This thread reminds me of a chop a friend did on a 48 Chevy coupe. It had at least 50 # of mud on the roof and it still looked like shit.
  27. punkabilly1306
    punkabilly1306
    from ohio
    The amount of time the PO spent on shaping mud could have been spent on doing better metal work, but alas, that wasn’t the case. But, that car got cut up and what could be saved was saved, and the rest scrapped.
  28. Danimal
    Danimal
    1. A-D Truckers
    What is your status in this, Bob? It’s been a hot minute!
