help me identify this rear please
Discussion in 'The Hokey Ass Message Board' started by drpepperdude, Dec 14, 2010.
  1. drpepperdude
    drpepperdude
    from newark DE
    I don't know what this rear is out of, it has the casting date on it and it says GM. I forget the date exactly but it was made in 1962. could someone tell me what kind of rear this is please?
  2. a picture would help!!!
  3. drpepperdude
    drpepperdude
    from newark DE
    you can't view the pictures on your computer?
  4. $um Fun
    $um Fun
    from Nor Cal
    I can see it fine.
  5. drpepperdude
    drpepperdude
    from newark DE
    the rear is in this truck, (notice the long ass (ladder bars??))
  6. Master of None
    Master of None
    Pontiac? what are the #'s on the front, that will help. Could be an Olds as well.
  7. F&J
    F&J
    I'm no expert, but it looks like full size chevy car
  8. austin514
    austin514
    i think 55-64 chevy but a better pic from the front would help . early olds-pontiac ?
  9. F&J
    F&J
    I was thinking chevy because the Olds/Pont were real round looking....but I don't know when they went to an oval shape?
  10. Dale Fairfax
    Dale Fairfax
    Since it still has axles in it, check the lug stud centers-Olds & Pontiac were 5 on 5, Chevy 5 on 4 3/4.
  11. drpepperdude
    drpepperdude
    from newark DE
    I didn't take a pic of the numbers because I have them wrote down somewhere but I can't find them,
    I zoomed in and it looks like 1|7|(2/3)|*|8|3|(8/3/6)
    | seperates digits, slashes in parenthesis is possible numbers, when I get a chance to see the numbers again I will get them exact(the truck is a half hour away)
    would a pic of the bottom of the dropout help anyone identify this?
    thanks everyone for your input
    Austin
  12. drpepperdude
    drpepperdude
    from newark DE
    thank you
  13. dorf
    dorf
    from ohio
    olds and caddy had a completely different u joint ,my vote chevy
  14. Black Panther
    Black Panther
    from SoCal
    Looks like a Chevy to me...probably 1962 Impala or 1962 Nova...same rear different width housings...
  15. drpepperdude
    drpepperdude
    from newark DE
    measured the lug spacing today and it is 4.5 inch wtf is that?
  16. sdluck
    sdluck
    Ford or mopar?
  17. sdluck
    sdluck
    How did you measure it?
  18. Did you measure from the center of one stud and then to long side of stud that is two away? Measure this way and it gives close to correct for a 5 lug pattern. Being GM it is not 5 on 4.5 pattern unless omeone changed the pattern, but that should be obvious looking at the drums and axles.
    My suspicion on your rearend with pics you have is a 62 Chevy rearend, as used on 55-64 Chevy cars. The fill plug on the back looks Chevy to me.
  19. 32-3 WINDOW
    32-3 WINDOW
    from utah
    looks like a early 10 bolt chev front drop out pumkin 55-64 also maybe has a ring gear scatter brace welded on a lot of the old front engine dragsters had this for nut support , if you know what i mean
  20. 56sedandelivery
    56sedandelivery
    Definitely a 55-64 full size rear end; also used in mid fifties to mid 60's Corvettes, and 62-65 Chevy II/Nova's. Same question about why the ring gear shield. Butch/56sedandelivery.
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Agreed, 55 thru 64 chevy car. I would say the houseing is tri five, because that panhard arm is homemade and there are no mounting points for upper arm for 58 thru 64s.
  22. drpepperdude
    drpepperdude
    from newark DE
    oh I measured from center to center i did it the wrong way then, I guess they are probably half inch studs so it would be 4.75, with that and what most of you are saying I have to agree its probably a chevy rear, as for the reinforcement on the back I dont know why it is on it, it has been like that for nearly 45 years now, it was supposedly raced in the 60's
  23. milner3268
    milner3268
    from buffalo NY
    its definately a 55-64 chevy unit with a panhart bar bracket welded on [and i dont know why a ring gear shield welded on as these rears broke axels,spyders or on a posi broke bearing caps] great street stuff with an auto. not so much for a stick and not for slicks[ as it is not a P case and wont last under abuse] trust me i have been there
