Hot Rods help me identify my heads
Discussion in 'The Hokey Ass Message Board' started by miky2001, Jan 13, 2022.
  1. miky2001
    miky2001
    from houston
    i got this chevy 350 motor and i dont know much about it, it runs good, but i would like to know where it came from.
    below are pictures of the casting marks on the heads.
    im confused.
    thanks in advance
    Deuces likes this.
  2. tomcat11
    tomcat11
    Last three digits of the casting number under the valve cover are probably 186 or 492. Post the letters and numbers from the pad next to the water pump leg and someone here will decode it for you.
    There s also a date code under the cover.
    Deuces and squirrel like this.
  3. Looks like two different head castings as best I can tell. One does look like a 186.
    squirrel likes this.
  4. squirrel
    is the suffix (last three of the stamped number on the block) TCY, or something else?
  5. miky2001
    miky2001
    from houston
    it looks like TCY, yes indeed
  6. tomcat11
    tomcat11
    TCY is a 1973 307 or 1982 305 C-10?
  7. miky2001
    miky2001
    from houston
    so its not a 350 i guess?
  8. tomcat11
    tomcat11
    What is the casting number on the back of the block driver side above the bell housing flange?
    Deuces likes this.
  9. My 186 heads look identical. Under the valve covers there is a casting number....give us that for a [positive I.D.
    Deuces likes this.
  10. miky2001
    miky2001
    from houston
    i need to go double check, i think it might be TJY
    I will have to try and get to that, very difficult to see, any tricks to get to see that?
  11. tomcat11
    tomcat11
    Ya in the car is sometimes difficult. A small mirror and a flash light? TJY is a 350.
    After another look those are two different heads.
  12. miky2001
    miky2001
    from houston
    i went out and checked and this is what i found:
    stamp is V1221TJY
    the passenger head says 3927186:
    and the drivers side head says 3947041
    the casting number is 3970010, i used some silly putty to find it, and flipped the picture around.
    what sort of a Frankenstein motor do i have? like i said, it seems to run nicely. its got a cam in it.
    Deuces and tomcat11 like this.
  13. Budget36
    Budget36
    Wouldn’t run without a cam in it;)
  14. squirrel
    The block is from a 1974 Chevy truck, according to the partial VIN C4F.... C means Chevy Truck, 4 means 1974, F is the assembly plant.
    The date codes on the heads show they're from other things.
    The 010 at the end of the block casting is what I'd expect for the block stampings. 350 block, most likely 4 bolt main, as used in lots of Chevy trucks and a few higher performance cars from 1969-1979.
    Deuces likes this.
  15. tomcat11
    tomcat11
    Both heads are from model years 69-70 302/350 and functionally the same. That silly putty trick is clever!
    Ericnova72, Deuces and squirrel like this.
  16. squirrel
    I wonder if it has a 350 crank, or if it's a 327? :)
    Deuces likes this.
  17. miky2001
    miky2001
    from houston
    i dont suppose there is any way to find out? this is the cam specs:
  18. squirrel
    you need to look at the crankshaft, or measure the stroke, to figure out what displacement it is. It' 97% likely that it's a 350. But you never know for sure...
    Deuces likes this.
  19. tomcat11
    tomcat11
    I'd bet dollars to dimes it's a 350 and probably been bored and rebuilt at some time. I have similar Crower Monarch in one of my 327's and it was great but now sits under the bench waiting..
    Deuces likes this.
  20. squirrel
    Dollars to dimes is only 90% likely that it's a 350 :)
    Deuces likes this.
  21. Deuces
    Deuces
    I think '72 was the last year for the 307....
  22. Deuces
    Deuces
    186 and the 041 head castings are almost identical..... except for the casting numbers....
  23. tomcat11
    tomcat11
    Ya, math never lies. :(
  24. squirrel
