Cleaned out a garage last week of some parts and need some help identifying a couple pair of wishbones. (insert "boner" joke here). The taller pair are better than 5 feet long, the shorter are about 4 1/2. (insert size joke here) What did they go to? What can they be used for? ("don't say the joke" light is flashing here) Better yet, what should I NOT use them for? Any info is greatly appreciated. Thanks, Bruce
For what it's worth, I think those are generally referred to as radius rods. Wishbones - split or unsplit - are usually seen in the front. And... the shorter ones look like Model A. Longer look like the ones I had from a '39 rear end and I'm sure were used on a few other model years. Hope that helps.
