I got a single barrel Rochester on my chevy 235, but I don't have any id-tag and need to rebuild it. So if someone knows what kind of carb i got I would be very happy!! Posted using the Full Custom H.A.M.B. App!
All I can tell you is it's a "late" version with fuel filter under the big nut and manual choke. Probably a truck.
Thank's guys ! It's leaking and hesistates when i push the pedal fast! Posted using the Full Custom H.A.M.B. App!
Leaking is pretty common, and a worn accelerator pump (or other problems with the engine such as timing, valvetrain, etc) are also pretty common. Like he said, try mid 60s chevy pickup 6 cylinder.
http://www.carburetion.com/CarbID/RochesterID.htm Pretty common carb, Model B or some variable of it. Most leak out the top where the four hold down screws have been over tightened. Joe
