History Help Identify Cadillac Bellhousing
Discussion in 'Traditional Hot Rods' started by 421-6Speed, Jan 12, 2020.
  1. 421-6Speed
    421-6Speed
    I'm trying to identify the manufacturer of this Cadillac bellhousing used on 54-62 331, 365 & 390 ci engines. The only casting markings I can find are on the starter cone KD 25 Any help would be appreciated.
    Thanks Dan
    20200111_154226.jpg 20200111_154246.jpg 20200111_154318.jpg 20200111_154148.jpg
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    that is a transdapt bellhousing
    mgtstumpy and 302GMC like this.
  3. 421-6Speed
    421-6Speed
    Thanks
    mgtstumpy likes this.
  4. krgdowdall
    krgdowdall
    from Alberta
    I found it listed for 55-64 Cadillac to a 55 up GM passenger, 3 or 4 speed. No indication of what flywheel or starter is to be used.
  5. 421-6Speed
    421-6Speed
    I think I can use Olds flywheel and Cadillac starter.
  6. Black Panther
    Black Panther
    from SoCal
    20131002_135231.jpg That is a very desirable adapter...it only fits Cadillc 1955 to 62..and you can put a Muncie or T10 behind it..
    warbird1, mgtstumpy and stillrunners like this.
  7. Chev38
    Chev38
  8. 421-6Speed
    421-6Speed
    Yep that is my plan.
  9. 421-6Speed
    421-6Speed
  10. TERPU
    TERPU
    You got Lucky! But Sqeek Bell also made a similar one at one time if anybody else is looking.
    And yes you can use and Olds Fly wheel on a Cad. You will need the Cad starter though as it mounts on the Passenger side. Same one you use with a starter flip on an Olds.
    - Tim
    Guess I should have read throug the post. That great chart explains it all.
