Technical Help ID body please
Discussion in 'Traditional Hot Rods' started by S10_37, Jun 30, 2020.
  1. S10_37
    S10_37
  2. alchemy
    alchemy
    Is that a tudor? If so, it's just a 30-31 Ford.
    S10_37 likes this.
  3. WTF really
    WTF really
    Doesn't that fuel shutoff make it a 31?
    S10_37 likes this.
  4. S10_37
    S10_37
    WTF really likes this.
  5. wheeldog57
    wheeldog57
    Sure looks like 30-31 Ford to me. Late 31 had teardrop shaped indent where fuel shut off is.
    I may be mistaken but. . . Murray's and/or Briggs did not have removable gas tank like the Ford.
    Good luck S10.
    S10_37 likes this.
  6. alchemy
    alchemy
    Later 31's had a indent around the fuel shutoff. Pretty sure (money back guarantee if I'm wrong) the early 31's had a smooth firewall like a 30.
    S10_37 and rust runner like this.
  7. You are correct Alchemy. The 1928-29 Fordors had the hidden tank, not the 1930-31 models
    S10_37 likes this.
  8. 1930-Ford-Model-A-Murray-Body-2-630x390.jpg and the way to tell if it is a Murray or Briggs body (if a 4 door sedan) is the the tops of the doors just above the windows has a slight curve to it if it is a Murray, the Briggs is straight there. This is a Murray body, see the top of the door glass.
    rusty valley, The37Kid and S10_37 like this.
  9. rusty valley
    rusty valley
    thats just a sediment bowl on the firewall, the fuel shut off is still inside on the tank until the late 31 indented pain in the ass fire wall came out. i have two pain in the ass fire walls, and i got tired of opening the hood to shut off the gas so i made a line back into the car, with a valve inside, then back out the fire wall.
    S10_37 and The37Kid like this.
  10. woodiewagon46
    woodiewagon46
    from New York
    The indented firewall was introduced in May of 1931. Rectangular reinforcements on the interior side of the firewall, near the radiator support bracket's were added beginning in October of 1930.
    razoo lew and S10_37 like this.
  11. sloppy jalopies
    sloppy jalopies
    does it have a steel of wooden subfloor ?
    S10_37 likes this.
  12. woodiewagon46
    woodiewagon46
    from New York
    I'm sorry that I didn't think of this in my previous post, but in mid 1930, Murray and Briggs placed their body style/ number plate or coach builder plate just below the Ford Patent Plate. I don't see their plate on your firewall. If someone removed their plate there should be two small holes under the Patent Plate If not, your body is a Ford body, as others have suggested.
    S10_37 likes this.
  13. S10_37
    S10_37
    steel but i cut it all out and made replacement skeleton from tubing
    Sent from my SM-J727R4 using The H.A.M.B. mobile app
  14. sloppy jalopies
    sloppy jalopies
    any briggs or murrays that I have had had wooden subfloors... if you have one stash the 2 rivet body # tag... handy later...
  15. Lloyd's paint & glass
    Scared the hell out of me, thought it was some kind of forensics :p
  16. making me dizzy...
    saltflats and rusty valley like this.
  17. 31Apickup
    31Apickup
    Briggs and Murray also did other A bodies than the for Ford. Those for Ford had wood subrails, but coupes and tudors had metal subrails. My 31 coupe is a Briggs built body, Murray and Ford also built coupe bodies. Not sure if only Ford built the Tudor’s.
