I have an engine that the timing mark does not line up with timing tab, I am guessing some one put it together with wrong vibration dampner, it could be the timing mark has rotated also. but if it is the wrong dampner does anyone know how far they are off? I have it running now and the mark is about 2 1/2'' above the timing tab. Another question. If you only setting the timing by listening, would you advance until in bings and back off until it starts good. thanks for input.
later stuff has the pointer behind the water pump....or about 2 1/2" from the other one..... as for the setting by ear , sounds like you got the idea
chevy moved the marks around through the years it's also possible the outer ring has slipped i suggest to bring # 1 cylinder up to TDC and remark you balancer or change your timing pointer. that's the only way you will know for sure your timing is right
you can put a timing tape on the balancer to match the pointer if you put #1 at TDC. but make dang sure the balancer ring has not slipped inside the rubber. unless there is a concern with keeping your current pully setup, a new one is cheap insurance.
