HELP - Air Suspension Guys -air line repair
Discussion in 'The Hokey Ass Message Board' started by fms427, Jan 29, 2010.
  1. fms427
    fms427
    So, I was welding bear claw door latches onto the shoebox, and, of course, a piece of weld splatter fell onto the plastic air lines - putting a pinhole in one and about halfway thru another.:mad::mad:
    Other than replacing the whole line, or installing a union, anybody know a PERMANENT fix, like epoxy, glue, etc.?? THanks !! Stan
  2. 59 brook
    59 brook
    nothing will work but a coupling don't kid yourself with epoxy
  3. Captain Freedom
    Captain Freedom
    from Upstate SC
    Napa sells dot air line, but its expensive!
    If you need to get it going in a hurry and don't have any more fittings/line go to lowes and get what you need to hard-line it with soft copper tubing and flared fittings. If you slip a piece of hose over the line and clamp it down with hose clamps, don't drive it anywhere except in your driveway.
  4. kraka138
    kraka138
    you could wrap it with duct tape.......:rolleyes:
  5. Go buy a couple unions and fix it that way or replace the line. That would be the correct fix that will last.
  6. aldixie
    aldixie
    Use a union. Nothing else will hold the preasure, I'm speaking from experience, I had the same thing happen to me.
  7. gnichols
    gnichols
    from Tampa, FL
    If the hole is small, a straight union cut into the line at the damaged spot will probably work. If not, use two straight unions to add a short piece of new line where the damage is located. Gary
  8. cretin
    cretin
    Why don't you want to use a union? They are easy enough to install and the best option short of replacing the line.
  9. farmer12
    farmer12
    Use a union, this will work. Otherwise replace the line. Good Luck
  10. Special Ed
    Special Ed
    This is not something to attempt the cheesy way out with. Fix it right.
  11. Jkustom
    Jkustom
    Why would you want to try fixing it any other way that actually fixing it?
    C'mon dude...
    If you stripped your oil pan drain would you stuff a cork in it and call it "fixed"?
    Peoples safety is in your hands.. Fix it the right way.
  12. greasemonkey060
    greasemonkey060
    Yep, do it right the first time. I wouldn't risk it, doesn't even matter which airline it is. Being stranded SUCKS.
  13. Mr48chev
    A union to repair the line should be available at any hardware store or Lowes or Home Depot for under five bucks. Enough tubing and fittings to replace that run shouldn't cost but a few bucks. I checked Summit and you can get enough to redo the whole car for a pretty reasonable price. http://www.summitracing.com/search/?keyword=air line tubing&dds=1
    It's too easy to fix it right without looking for some half baked fix that may or may not work.
    I don't have air suspension and there is a 99.99 chance I never will but if I did, I'd make sure that I had enough spare tubing to replace the longest run in the car, unions to splice the tubing and nuts, sleeves and ferrules to replace at least two ends on any line on the car any time. Plus the tools to make the repair. The whole bag of stuff would be under 20 bucks and save a guys ass if a line or fitting crapped out on the road.
  14. greendream
    greendream
    I would suggest just replacing the whole line.
  15. junkcad
    junkcad
    from nashville
    me too
  16. c1run1
    c1run1
    from TRNJ
    Black pvc air line from a Large truck shop ( Mack Petterbuilt ect ) or parts / dealer is cheap and local on the shelf .
