Technical Help 350 chevy popping in exhaust
Discussion in 'The Hokey Ass Message Board' started by Archer775, Aug 18, 2014.
  1. Archer775
    Archer775
    Ok so I have a el camino with a 350 2 bbl carb HEI dist and I have recently put on new headers and true duals on it and it has a popping from the exhaust. I have messed with the carb a little and the popping didn't really go away it got better but didn't go away
  2. saltflats
    saltflats
    from Missouri
    Do you have room to install a balance tube in your exhaust ?
  3. I'd bet you have an exhaust leak.
    I'd double down if popping showed up right after your new headers went on.
  4. Archer775
    Archer775
    Yes I do have room for one
  5. Archer775
    Archer775
    It doesent sound like it has and leak at all the exhaust leaked really bad before with the original single exhaust
  6. Archer775
    Archer775
    Oh I'm sorry enlighten me on the rules where can I find the rules at p.s. I'm 16 and don't have a mullet
  7. tfeverfred
    tfeverfred
    TRADIONAL (PRE 1965) HOT RODS AND CUSTOMS. We live in the past here. Ryan's time machine had only one setting and we all hopped in. Johnsons in the White House and our boys are fighting on foreign soil. The Mustang looks okay, but we're holding out. The Beatle's are good, but we won't admit it. The Beaach Boys ROCK. CUT YOUR HAIR!
    Hill_County-rodshop and hrm2k like this.
  8. big duece
    big duece
    from kansas
    I think he meant 1965, with a 350 that was put in later. Go with it Archer... let's slide some slack, at least its not an blazer 4x4 chassis conversion, or is it??
  9. Archer775
    Archer775
    Ok so if it didn't pop before with stock exhaust how could valve springs be a problem
  10. Archer775
    Archer775
    No it seams to have as much power as it should
  11. alphabet soup
    alphabet soup
    Make sure you don't have plug wires 5 and 7 crossed.
  12. Archer775
    Archer775
    But I guess I didn't get as much increased performance as I hoped for
  13. Archer775
    Archer775
    I'll try the spark plug wires because i did have to remove all wires and plugs to get the headers in
  14. tooljunkie
    tooljunkie
    from manitoba
    my money is on the wires..18436572. but we all know that.
    i prefer to start with rotor pointing at #1 cylinder,tdc.
    good luck
  15. El KaMiNo KiD
    El KaMiNo KiD
    Maybe a loose plug...
  16. models916
    models916
    Vacuum hose off somewhere!
  17. .. lest us not forget the Marlboro cigarette jacket and HD sticker on the back window.
  18. Russco
    Russco
    from Central IL
    Is it popping when you let off of the gas ( deceleration) ? If so like Vicky stated I'm betting its an exhaust leak.
  19. Are you using Champion Spark plugs? HRP
  20. Archer775
    Archer775
    I'm using standard AC delco plugs and yes it mostly back fireds when you let off the gas but it also does it some times when your sill in the gas
  21. Lots of things to look at, as 31Vicky said exhaust leak, also the 5 and 7 plug wire crossed is something to watch for, I have been at this nearly 45 years and still cross them on occasion. Look for a loose wire in your ignition circuit as well, maybe coming off the switch or where is connects to the distributer, a momentary laps in zot to the dizzy will cause a back fire.
    I don't care if you need a hair cut or not by the way, be yourself first and let the chips fall where they may.
  22. Archer775
    Archer775
    Could the carb be off? Sounds to me like maybe it's not getting enough gas
  23. Archer775
    Archer775
    5 and 7 wires are correct
  24. It sounds to me that you need to richen the fuel mix to compensate for the more efficient exhaust system (lean mis fire some call that). You might also advance the timing a hair and see what that does just for kicks
    Hill_County-rodshop likes this.
  25. Archer775
    Archer775
    That's exactly what I thought
  26. Let us know what you find out. Part of the reason we all help is to learn. That's hard to do when the person doesn't report back just "what" fixed the problem.
    NOPSI and Russco like this.
  27. Archer775
    Archer775
    I fixed it the carb was way way lean now it doesn't back fire hardly at all :).
    NOPSI and Groucho like this.
  28. COOL! THX
