Technical Headlight / Park Light wiring question
Discussion in 'The Hokey Ass Message Board' started by Petejoe, Mar 7, 2018.
  1. clem
    clem
    To original poster,
    Read post 8 and post 21 and then please do it correctly.
    olscrounger and Petejoe like this.
  2. clem
    clem
    Maybe time to either up your standards or get a professional in.
    Sorry to sound harsh, but you are potentially playing with fire......
    olscrounger likes this.
  3. Kerrynzl
    Kerrynzl
    Hey mate if you want to create difficulty by adding components ^^^ is the way to do it.
    OR
    Tap a wire off AFTER headlight switch but BEFORE the high / low beam switch
    OR
    Tap a wire off the taillight circuit which is switched on by the same switch. Even antiquated old HAMB friendly cars have taillights.
    Now , if you use the Taillight circuit option, you can also find another power feed and use another parklight switch [on the dash] and tap that back into the taillight circuit. The headlights would be off so you can still have Fr/Rr parklights
    Frankie47 and Petejoe like this.
  4. Kerrynzl
    Kerrynzl
    Petejoe, olscrounger and Crazy Steve like this.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Thanks everyone for your insight. You’ve gotten through.
    Kerry , I love your drawing. I do plan to run a parking light circuit and rewire my switch with a separate hi/low beam toggle. PJ.
  6. hayu
    hayu
    my 2 cents worth no forget it it won't help anyway.
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    Kerrynzl likes this.
  8. clem
    clem
    Thanks,
    I will sleep better tonight, and possibly others here also....
    Petejoe likes this.
  9. trollst
    trollst
    Boy, talk about making an easy simple job tough. -----power to headlight switch, wire out to tail lights-park lights, wire out to dimmer switch, after dimmer, two wires out to headlights, one, low beam, one, high beam, ground each headlight at the mounting point or somewhere on the car close to headlights.
    Don't let the smoke out of the wires, it'll do bad things to your car.
    clem likes this.
