Hot Rods headlight fitment issue 40 deluxe
Discussion in 'The Hokey Ass Message Board' started by 1947coupe, Mar 25, 2021.
  1. 1947coupe
    1947coupe
    Having issues with alignment tabs on bulbs hitting rims, do I grind these off or is there a better solution, using 12 volt system, thanks.
  2. Jim Bouchard
    Jim Bouchard
    Yes, I have run into this problem before.
    I have sanded the nubs off with an angle grinder and a fine sanding disk.
    I also run the sanded off part under the buffing wheel to make it shine more after sanding it down.
  3. Zax
    Zax
    1. 1952-59 Ford Social Group
    I've ground them down using my Dremel and a stone grinding bit. But be sure to use protective gear. You don't want to breathe in or get that dust in your eye. Nasty stuff.
    olscrounger and lothiandon1940 like this.
  4. 1great40
    1great40
    from Walpole MA
    Drake used to sell them all ground. Not sure if he still does.
  5. 42merc
    42merc
    I take them off with a bench grinder using a fine grit wheel.
    Go slow.
    lothiandon1940 likes this.
  6. I bought some without tabs from Speedway last year.
  7. hoop
    hoop
    Glass shops have sanders to do that.
  8. 1947coupe
    1947coupe
    I think I'll let the glass shop do it, have to pick up my side glass anyway, thanks.
