Customs Headlight and taillight switch
Discussion in 'The Hokey Ass Message Board' started by greaser 35, Mar 30, 2022.
  1. greaser 35
    greaser 35
    from FRANCE
    Hello ! I am in the final phase of the connections my 12 v wires on my 1954 Ford customline , only here I am lost for the connections on the switch foot and on the switch light! Can you tell me how to plug in the headlights, taillight and ? What wires go on witch foot and switch light?With a sketch would be nice!!
    Thank you soo much !! Stef from France
  2. Country Joe
    Country Joe
  3. Mr48chev
    The short version is.
    Wire from headlight connection on headlight switch to foot dimmer switch
    The dimmer switch has one in and two out connectons. This means that when you connect your ohm meter to one pin, you should have continuity to one of the other pins and when you work the switch you have contuinity to the other pin. You should not have continuity across the two pins that go to high and low beam.
    Connect the wire from the headlight switch to the "in" pin
    Connect the high beam wire to the lights to one side of the dimmer switch. Your high beam indicator light will also connect to that side.
    Connect your low beam lights to the other side.
    I'll look some more for the wiring book when I get back from an errand.
  4. 24riverview
    24riverview
    Assuming it's a floor switch it probably looks like one of the ones pictured. On any 3 terminal dimmer switch the "center" terminal is where the headlight wire from the light switch goes. Doesn't matter which way you hook the high and low beam wires to the other 2 terminals. Don't forget the high beam indicator wire goes with the high beam wire on same terminal (may be tied together in harness already). Tell us what headlight switch you're using, should be able to provide a diagram for it also.
    jd34delivery likes this.
  5. greaser 35
    greaser 35
    from FRANCE
    My headlight switch
    My foot switch
  6. I have trust issues with old HL switches. Especially those with the glass fuses. When I ordered my harness kit, I got their HL and dimmer switches.
  7. 24riverview
    24riverview
  8. 51504bat
    51504bat
    Wiring diagram for your headlight switch
  9. greaser 35
    greaser 35
    from FRANCE
    Kool , Thank you soo much !!! It works!!!! now my other problem it's the right turn signal it doesn't work, the left is OK but the right NO ???
  10. 51504bat
    51504bat
    Bad ground is the first place I'd start.
