Hot Rods Header gaskets
Discussion in 'The Hokey Ass Message Board' started by woodiewagon46, Oct 5, 2018.
  1. woodiewagon46
    woodiewagon46
    from New York
    Over the winter I'm going to install a set of Sanderson Headers on a small block chevy. Sanderson tells me that no exhaust manifold gaskets are necessary and recommend Permatex Ultra Black sealant. I'm ex Navy power plant mechanic and 50 years in industry. Every situation I have ever encountered with exhaust manifolds required a gasket. When I asked the Permatex people about Sandersons recommendation in using the Ultra Black, he replied "I wouldn't, it's only rated for 500F max". I can understand that they might be the flatest flanges there are, but cast iron heads aren't ground perfectly flat, they are "fly cut", hence the stock gasket. Am I too old school?
  2. old sparks
    old sparks
    rtv orange hi temp is what I use. bolt headers finger tite after application next day cinch em down
    X-cpe and chryslerfan55 like this.
  3. saltflats
    saltflats
    from Missouri
    I would use the ultra copper.
    GM never used gaskets from the factory.
    upspirate, squirrel and flatheadpete like this.
  4. Cheap header gaskets(like the ones you get in standard rebuild sets) will eventually leak but I can't see where a quality gasket will hurt anything.
  5. flatheadpete
    flatheadpete
    from Burton, MI
    I use the steel gaskets that GM used in the '90's.
  6. squirrel
    Some GMs used gaskets, but most Chevy V8s with iron manifolds didn't. They did have lock tabs, to keep the bolts from loosening, on the outer 4 bolts on small blocks, and interference fit threads on the bolts on big blocks.
    If the mating surfaces are flat, and the header flange is thick, and you can keep the bolts tight, gaskets (or RTV) should not be necessary.
  7. I know quite a few people that use ultra copper with their Sanderson headers without any trouble. I don't know of anyone using black.
    Personally I use SCE copper gaskets on my car but the headers are not Sanderson but rather, FPA
  8. greybeard360
    greybeard360
    Look into Percy's header gaskets. I have used them on several cars and they work great. They don't look anything like other gasket materials you are used to seeing... They are actually kind of fuzzy. I used them on my OT AMC 360 and they never burned out between the center ports like they others I tried.
    Raunchy likes this.
  9. Beanscoot
    Beanscoot
    If the fit between the two components is good there will be good heat transfer between the two surfaces, so the sealer, if used, shouldn't see much more heat than that of the cylinder head.
    In other words, the manifold surface shouldn't be much hotter than the head surface.
  10. D2Denny
    D2Denny
    I have Sanderson's on my Red Ram. Used Permatex red hi temp RTV, followed Sanderson's instructions allowing the RTV to skim up before installation. Been running 2 years now leak free.
    nochop likes this.
  11. jaw22w
    jaw22w
    from Indiana
    I bought a set of Sanderson headers last year. They specifically state: Do not use a gasket because it can cause the flange to distort. I followed their directions. Put 1/8" bead of red RTV on the head. Let set over night. Then install header. Been on there a year and no leaks.
    I had a sealing problem with a set of homemade lakestyle headers on another car. Tried this method and have had no more problems.
    I would not second guess Sanderson's directions. It works.
  12. tfeverfred
    tfeverfred
    When in doubt, follow the directions.
    X-cpe, bobss396, upspirate and 2 others like this.
  13. dirt t
    dirt t
    1. HAMB Old Farts' Club
    When all else fails read the instructions if you still fail follow the instructions.:)
    X-cpe and nochop like this.
  14. Beanscoot
    Beanscoot
    For what it's worth, I used to use a thin skim of graphite grease between exhaust manifolds and heads when not using a gasket. I don't recall now where I heard this recommendation, it was a long time ago.
    It worked very well.
  15. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    I get the powerplant part. I would not use rtv either. I love the remflex gaskets. 10+ years and no leaks. I'm sold.
    egads likes this.
  16. woodiewagon46
    woodiewagon46
    from New York
    wbrw32, when the people that make the sealant, Permatex, tell you that the would not use the Ultra Black then I would take their advice. There is no reason to call people a dumb ass and hope it never seals. Try to act like an adult. Lots of other good advice from others. I'll go with the red or copper.
    Raunchy and harpo1313 like this.
  17. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Hey he is a self proclaimed parts specialists from the "traditional days". From what I have seen is that this guy doesn't know shit other than how to be an ass to others. I don't think he really knew anything in his day and it seems to be the same today.
    chevy57dude and Raunchy like this.
  18. Those tabs were GREAT for catching a passing knuckle.... I have never used a gasket (most gasket sets come with them..) on a SBC with cast iron exhaust manifolds. Make sure everything is clean, run a flat file over the mating surfaces just to be sure. I would tend to side with Sanderson's advice. When in doubt in the past on oddball installations, I've made up copper gaskets and that always worked. I've also used this copper spray from Permatex, it says it stands up to exhaust heat in the ad.
    https://www.permatex.com/products/g...rmatex-copper-spray-a-gasket-hi-temp-sealant/
  19. olscrounger
    olscrounger
    Have installed quite a few sets of Sandersons on small blocks and used either the black stuff they recommend or the copper stuff--none have ever leaked if installed per instructions-maybe I'm just lucky
    bobss396 likes this.
  20. Wow!.... Retired motivational speaker?......Enron HR manager?:)
  21. s55mercury66
    s55mercury66
    from SW Wyoming
    I have used Permatex blue, red, and copper on header/manifold gaskets over the last 40 years, and never had an issue. I like to snug headers up, and give them a final torque the following day, although I have been guilty of just tightening them up on installation and running with them. That has been my honest experience. Like some of you have mentioned, on sbc's, I will run manifolds without gasket if the surfaces are good enough to do so. RTV, like thread tape, can be your friend, when used in moderation.
    olscrounger likes this.
  22. THIS IS NOT EVEN WORTHY OF A COMMENT.....
  23. chargin03
    chargin03
    No gaskets needed works for me on three cars.
  24. Blue One
    Blue One
    from Alberta
    Header gaskets.
    One word.
    Remflex.
    The 39 guy and egads like this.
  25. Raunchy
    Raunchy
    Seems odd they would recommend Ultra Black when Permatex states it is for gaskets and oil resistance up to 500 degrees and Ultra Copper is recommended by Permatex for exhaust gaskets and is rated at 700 degrees. I use the copper and would recommend it over the black although I have never used the black on an exhaust . I use Percys soft gaskets on my stuff and reuse them with a little Ultra Copper and have no leaks. You may have to try some of these recommendations and see what works for you.
  26. blowby
    blowby
    from Nicasio Ca
    Are the Sanderson flanges different from the norm? Been reading the advice above, I have Hookers on a SBC. Every set of headers I ever bought came with gaskets...and many failed..
    The rebuild gasket set I have has the ones with metal on one side, paper on the other.
    nochop likes this.
  27. squirrel
    The exhaust gaskets in a SBC gasket set are an interesting item....Chevy didn't use gaskets on the manifolds (with iron manifolds), but the gasket companies make gaskets for them. I don't understand it all.
    For typical headers, I would use the composite graphite gaskets, such as Fel Pro 1404 or 1426. Make sure the hole in the gasket is small enough that it seals all the way.
  28. nochop
    nochop
    from norcal
    I got good at changing gaskets, thought it was one of the small joys of having a hot rod
  29. jimmy six
    jimmy six
    Used red RTV on nitro engine at Bonneville with no problems. We us a 3 piece aluminum gasket on our dirt rear crossover headers and get 2 seasons out of them.. They need tightening after every race.
  30. Beanscoot
    Beanscoot
    "The exhaust gaskets in a SBC gasket set are an interesting item....Chevy didn't use gaskets on the manifolds (with iron manifolds), but the gasket companies make gaskets for them. I don't understand it all."
    Same with Ford. But then someone will eventually install gaskets, and with age the gaskets will partially crumble away. If the missing gasket material is under a bolt "ear", then next time the bolts are tightened there's a good chance the ear will be broken off.
