Hayden Model T-100-S Heavy-Duty Parts Washer. Runs on 240 volt 50 amp single phase feed from your circuit breaker. My deceased friend built automatic transmissions and cleaned all cores and parts for the transmissions in it. Also can clean engine blocks, pistons, manifolds etc. The detergent that is used is safe for aluminum. The heated water really gets the parts clean. The Hayden brand name was taken over by Trans Tool who still produces this model with only minor changes over the years. Made in the U.S.A. in the same buildings since 1978 by Quality Names you can trust! Trans Tool LLC / Hayden / ATEC . Most parts if needed are still available. Here is a reference for details of the current model closest to this one https://www.bestbuyautoequipment.com/trans-tool-hd-parts-washer-p/t-0100-s.htm. The newer unit has an oil skimmer added and is 3 phase instead of single phase and maybe some other differences. It is in good operating condition and has many years of use left in it. With a fresh coat of paint it would look good. It is still connected and can be tested before buying. More pictures available if wanted. 100% of proceeds to widow ! This item weighs approximately 750 lbs and can be lifted with an engine hoist for loading Local pickup only, you load. Asking $1500 obo.
