Hot Rods Hard to find lug nuts?
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Aug 31, 2021.
  1. JimSibley
    JimSibley
    So, i found an old set of ansen 5 spokes for the frint of my car. It needs .62 diameter shank on the mag style lug nuts. They are 1/2x20 and all i find ate .68 diameter on the shanks. Does anyone know where i should look for this?
  2. egads
    egads
    VANDENPLAS and bchctybob like this.
  3. squirrel
    Where could you find an 11/16" drill bit?
  4. The only ones with a .62" diameter shank I'm seeing are for the old unifit ET mags, but those have a tapered seat to seat in the washer.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The extra wall thickness would be beneficial.
  6. There's a fair selection in tapered seat type lug nuts in that size, maybe a countersink with the right angle would be the easiest solution.
  7. squirrel
    I don't know, I can't see the wheels. I doubt it would make a difference though.
    I wonder if the wheel material is up to that? Seems to me that aluminum wheels all used shank nuts with washers, until they finally started using aluminum that was strong enough to survive with tapered nuts. I'm just asking a question, I don't know the answer.
    oldiron 440 likes this.
  8. The modern aluminum wheels with tapered seat nuts don't have that much material at the lug holes from what I've seen. While the flange is thick, by the time they countersink the nuts there's maybe only 3/8" thickness left at the actual seat. To be honest, I was surprised it was so little. If you don't get carried away with the countersink and get a nut with a shank as long as possible it should be fine.
    Whether this is easier/better than drilling the lug holes out to .68" is the question. I would think it may be easier to maintain hole centers with a countersink vs drilling, but maybe not.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ??? I was only referring to the shank of lug nut.
  10. JimSibley
    JimSibley
    Here are the wheels, and the old airheart brake setup i want to run them on. I can drill them to 11/16”,I just thought if i can find the right lug nuts, why not use them. 920E0883-4D65-48F4-A0ED-6A64245AC497.jpeg
  11. DDDenny
    Jim
    Trying to drill out only 1/32"/side,1/16" total with a regular bit is touchy, might try a reamer instead.
    You'll get a rounder hole and not go too far oversize which is highly likely with a drill bit.
    5window, LWEL9226, pprather and 2 others like this.
  12. squirrel
    There isn't a whole lot of meat on those wheel centers...but still, it's only 1/32 you're removing.
    Another option is to stick normal 11/16 shank nuts in a lathe and make the shanks smaller. Either way, you probably want longer studs.
    pprather, alanp561, Deuces and 2 others like this.
  13. Are you sure that you have 1/2" diameter wheel studs ? If you were to use a .62 outside diameter lug nut you wouldn't have a lot of wall thickness for the shank of the lug nut. .62, minus .500 ( 1/2") = .12 divided by 2 equals .06, or 1/16 " of wall thickness. Is that enough to be safe ?, or possibly cracking, or splitting the shank of the lug nut ?
    Deuces likes this.
  14. @JimSibley
    I just went through the same issue although mine are 7/16" GM. I have a pair of very hard to find Crestline that used the small shank so instead of taking chances with expensive wheels I took them to the machine shop and set them up on the mill to the correct bolt pattern and enlarged the holes to the correct size. Took more time than a drill but I know they're correct. With yours being 5 1/2" bolt pattern I wouldn't want to take any chances. If those are Ansen and 5 1/2 bc they're kinda rare also. What width are they ? I've not seen Ansen with the pointed spokes like that. Do they say Ansen on the back ?
    VANDENPLAS and alanp561 like this.
  15. Plan 1: turn down a few lugnuts and see if you like that solution.
    If not,
    Plan 2: ream the holes on your vintage wheels to accept available lugnuts.
  16. JimSibley
    JimSibley
    They have no markings, the guy i got them
    From said they were ansen, but i dont know for sure. They are 15x6 and they are 5x5.5, that is all i know.
  17. Ansen's from the period always said Ansen Gardena, CA on the back and early ones even have ser. numbers. Still cool with a 5 1/2 bolt pattern can you post a picture of the back side it may help identify them.
  18. JimSibley
    JimSibley
    There are no markings anywhere on these things. A5B1A372-F792-427F-8B77-55CF3EC8EC3F.jpeg 5574078D-6D6C-4139-BBD2-C2EDA41802BC.jpeg F56E92B8-07B7-44CB-8E56-673D842DC1E6.jpeg
    VANDENPLAS likes this.
  19. JimSibley
    JimSibley
    Well, I manned up and drilled them to 11/16”. As usual, squirrel was correct. I will post pics as soon as i have them on the car.
  20. MCjim
    MCjim
    from soCal
    Fine, I ran into the same thing with my old Torq Thrust D's, worked great.
    41 GMC K-18 likes this.
  21. JimSibley
    JimSibley
    Happy with my wheels. They go
    Well with the airheart brakes, and i dont need wheel adapters.
    pprather and squirrel like this.
