Hanging pedals
Discussion in 'The Hokey Ass Message Board' started by 1930 A, Aug 13, 2006.
  1. 1930 A
    1930 A
    I have a 1930 Model A sedan. The master cylinder is under the floor. I'd like to move it to the firewall and have a hanging brake pedal in the car. Has anyone done this and if so what did you use for a pedal and brackets .
  2. BZNEIL
    BZNEIL
    I used willwood clutch and brake pedal setup. I have the master cylinders mounted on the firewall with some support structure weled on the inside. Worls great.
  3. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    I used a reverse Willwood set-up....The masters are facing you and hidden by the dash cover....
  4. Wilwood
    Coleman
    Tilton.
    Google all of them and you should get a good idea.
    I have a Tilton setup in my truck and a Wilwood setup for my roadster.
  5. curtiswyant
    curtiswyant
    I've used S10 pedals and a '52-53 Ford hanging pedal setup in a Shoebox. Cheap and "OEM." I've heard 300ZX pedals work well, too.
  6. Paul
    Paul
    Editor
    for '60s trad
    Ansen originals
    Speedway coppies
    and now Tardel too!
