When charging a 6V battery for a system that is + ground, do you hook the red lead from the charger to the + terminal or the - terminal? I would think that you would hook it up like a - ground system (Red to +, black to -), then install it + ground in the vehicle. This is a new guy to + ground question that I'm sure needs to be clarified.
You still charge it the same as a - ground system..... At least I do.... If it is hook-ed up backwards your charger will probably let you know...... HC
Red to Red, Black to Black.... My charger freaks out (Buzzes and the needle jumps all around) if I hook it up the other way. Mike
