Technical Got her to start but won’t idle
Discussion in 'The Hokey Ass Message Board' started by Christie, Jun 6, 2020.
  1. I believe it’s the original column
  2. Not positively sure. How can I tell this?
  3. loudbang likes this.
  4. fresh hops
    fresh hops
  5. lostmind
    lostmind
    If the brake lights work , it most likely is a bad turn signal switch. Could be bad connections at the switch connecter. If the brake lights don't work , check the bulbs. The turn signal and brake use the same filament in bulb. Might be a ground problem , but usually the tail lights will be very dim.
    You should use a test light or voltmeter to check at the turn signal switch connector for voltage on the turn signal wires. You can get the wire colors off of a diagram.
    good luck , you can do it.
    Christie, Johnny Gee and loudbang like this.
  6. 51504bat
    51504bat
    You're not clueless, just smart enough to ask someone who has been down the road before you. Saves a lot of aggravation and allows you to move on the the next problem. LOL. A complete rewire for my '54 Ranch Wagon is in the near future so I'm sure I'll have issues as well. With your perseverance and the helpful HAMBER's you'll sort it.
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Christie since others have commented that your vehicle came factory with signals X2 for this quote.
  8. Thank you for your faith in me. <3
  9. Thank you for your help, I’ll take a look later today [emoji16]
