Features Good or bad let us see pictures of your F1 or F100!!!!
Discussion in 'The Hokey Ass Message Board' started by 56fordf100, Dec 16, 2008.
  1. I've know that, about myself anyway, for years!
  2. '56 F-100 towing our '28 roadster project
  3. 57 - 72 p/u is as close to a direct bolt-in as you'll find. As long as the axle is put back in the stock position (under the springs, etc) it is the correct width, spring pads are in the correct place, and pinion angle is the same. The 9" is bigger around so you will need larger U-bolts though. Additionally a drive shaft may need to be fabed depending on application.
    If you move it above the spring for a drop pinion angle may need to be adjusted, but that's not difficult.
    Yes.
  4. kidzintha34fodor
    kidzintha34fodor
    Here are a couple that passed through my hands this summer. The 56 used to belong to Chris.
  5. I like 'em both!
  6. damagedduck
    damagedduck
    from Greeley Co
    Ok since this has turned into a info thread,the beam under mine is kinda questionable,what other beam will fit?anybody here done the yoda steering box swap?
  7. Lol, no problem...
    I traded for this truck back in December. It was in really good shape with a lot of the body work already done.
    It has a Chevy 350 under the hood mounted to a turbo 350 tranny and ford 9" rear (done by previous owner).
    The suspension consists of monoleafs that center the wheels in the fenders in the front with a CPP 3" drop axle. (I would not recommend this axle to anyone! I had to have it machined just to fit and now installed the camber is -2 degrees. Its not a choice I would go with again). I also added a front sway bar and gas shocks.
    The rear has Camaro leaf springs (I think they are) and I flipped the axle on top. I did notch the frame to get this done and added gas shocks. The sway bar I bought did not fit so I am looking for another that will fit.
    As it sits, the running boards are 5" from the ground and the tailpipes are 2" from the ground. The only time I scrape is going over speedbumps. Besides that it rides great.
    Since I purchased it I also installed front power disk brakes, finished the interior off by making door panels, kick panels, and adding carpet. And I changed it from a colum automatic shift to a floor shift automatic with a tall Lokar swan neck shifter.
    As I said... its a work in progess. Hope this helps the "rest of the class". LOL
  8. Twisted_Fate
    Twisted_Fate
    unfortunatly i only have pictures that i decided to randomly take and styleize, but this is how it sits right now.
  9. Nice truck Twisted Fate!
  10. Well, it looks great! Thanks for sharing.
  11. What do you mean by "questionable"?
  12. Good looking truck. I also liked it with the steelies.
  13. Twisted_Fate
    Twisted_Fate
    thank you very much!
    Just a few more and il stop!
    My Girlfriend says i take to long to give my f100 a bath so she decided to do it for me... me and my buddy were watching from lawn chairs before we all went out for a cruise
    and just a cruising shot arm hanging blimp in the air in the deep background!
  14. She's a keeper!
  15. I'm in. My new F100 shorty. Probibly be selling it soon.
    Sent from my DROID device using the TJJ mobile app
  16. Hell, you can't wash a Chevy that way...It'll Rust...lol
  17. AZAV8
    AZAV8
    from Tucson, AZ
    I like your truck and that you use it to tow. Is that your Featherlite trailer? How do you like it? I'm considering getting one for my self to use with my 48 F1 when its finished.
    Whose trailer hitch did you use on the truck or did you fab it yourself?
  18. duste01
    duste01
    Ok, I broke down and took a picture of mine. There ya go. Oh, and by the way. If you want to put a receiver hitch on a truck like this. The same one that you can buy to fit any ford pick up, up through the 80's will bolt in. Mine is a reese. This is my daily driver.
  19. bigbackwindow1956
    bigbackwindow1956
    I'm new to the site, but here's mine.
  20. Big Back Window. What kind of box is that, it looks as if it is wider and are those 3' wider fenders?
  21. Landry
    Landry
    from NH
  22. Frank32
    Frank32
    Here is another picture for the collection...
  23. Flathead Johnny
    Flathead Johnny
    from MA
    i have chatted with you at the Amherst swap meet
  24. Flathead Johnny
    Flathead Johnny
    from MA
    i'm wondering what size wheels you have on the f100?
  25. Frank32
    Frank32
    Stock rally wheels w/hupcaps, tires - coker classic G78/15 & L78/15. I hope this helps.
    Frank
  26. Ok, you asked for it...
  27. Landry
    Landry
    from NH
    Flathead jonny ill be there tomorrow
  28. Dave50
    Dave50
    Thats a Bitchen truck!!
  29. garman34
    garman34
    Here is mine. 1954 F100.
  30. damagedduck
    damagedduck
    from Greeley Co
    Your's kinda looks like my 53 ?????:)
