Hot Rods Good bye Flaty, HELLO Caddy!
Discussion in 'The Hokey Ass Message Board' started by CheatersPete, Mar 30, 2015.
  1. CheatersPete
    CheatersPete
    Hi
    After driving my 32 roadster for the past 2 years with flathead engines, an opportunity of getting a low mileage 365 for a fair price arrived a month ago.... I always have been a big fan of Flathead engines, the last one I built is a stroker 286, full ported, with 270f schneider cam, milodon valves, lincoln springs, and lot of goodies... the car runs great.
    I decided to jump on the opportunity to get this early caddy OHV, as it only have 60k miles on it and runs great and i think it will still fit with the spirit of the car. Also, any hot rodder of the middle 50' will have done it if possible ;-)
    Here is the engine, I'm working on the cleaning at the moment...
    I will bolt my T5 transmission via an adapter kit from Wilcap.
    Please let me know if you have any advice that I should be aware off...
    Cheers
    slammed and lothiandon1940 like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    You will love it! I did the same to my 40 a few years back and it is a much more fun to drive car now ImageUploadedByH.A.M.B.1427730907.391980.jpg ImageUploadedByH.A.M.B.1427730929.079959.jpg
  3. CheatersPete
    CheatersPete
    Can t wait to try it ;-)
  4. wvenfield
    wvenfield
    Flatty's are cool in their own right but one can't complain about swapping in a Cadillac.
    tb33anda3rd likes this.
  5. 2935ford
    2935ford
    engine weight difference? :)
  6. Moriarity
    Moriarity
    SUPER MODERATOR
  7. 56shoebox
    56shoebox
    What about the radiator? Can you use the same one and tee the two radiator inlets together, and the same for the two outlets?
  8. CheatersPete
    CheatersPete
    Yes the caddy is heavier ;-(, I will keep the original radiator and engine mount and adapt .
  9. Hyfire
    Hyfire
    The 365 is a great engine. All of the early 331 bugs were worked out much earlier and the quality is there.
    Only thing you are missing is an Eldorado Q-code intake, but I'm guessing you're going aftermarket. Also, parts are easy to get on any 331-365-390.
  10. Oh the horror of it all..................................:(:(:(
    Texas Webb likes this.
  11. At least its not an sbc.:D
    warbird1 likes this.
  12. Gene Boul
    Gene Boul
    I more or less agree with your decision. While I love flatties I guess the only thing that would kind of be acceptable is an early Caddy! Good choice. g
  13. belair
    belair
  14. CheatersPete
    CheatersPete
    The caddy was the only ohv I will swap against my flathead :) Thanks for Your comments
    Moriarity likes this.
  15. Weird, I didn't realize the Caddy/Olds motors of that era were so heavy. Having wrestled with a Flathead swap last summer I would have bet they were comparable.
  16. ididntdoit1960
    ididntdoit1960
    from Western MA
    NICE car - Nothins' lackin' when your Caddilacin'
    lothiandon1940 likes this.
  17. 40fordtudor
    40fordtudor
    Like the line from "Dances with Wolves"---good trade.
  18. seatex
    seatex
  19. CheatersPete
    CheatersPete
    When using an aftermarket valley cover , what are you doing with the rear vent tube that was in the original valley pan ??
  20. deto
    deto
    I dig it...
  21. coupe33
    coupe33
    I took my new valley cover to the local machine shop and used an old (60's) straight up valve cover vent They machined the ribs and flat machined the top so it would sit right. Just make sure they machine between the bolts in the valley pan. The other choice is to add a PVC vent and PVC.
  22. CheatersPete
    CheatersPete
    OK, will do at too
  23. Road Angels
    Road Angels
    Just an Idea..... take the heads of the flat head and make then into valve covers for the caddy engine, acorn nuts and all....................damn pain meds. I keep invisoning things
  24. CheatersPete
    CheatersPete
  25. foolthrottle
    foolthrottle
    Sounds like the right choice for the right car, you don't see those wheels very often.
  26. Road Angels
    Road Angels
    Damn didnt see the wheels, very cool thanks for pointing it out, NOW the big question and the one every one has in the back of there mind WHAT COLOR
  27. CheatersPete
    CheatersPete
    Some news, Engine finally in!
    Have to work on the engine mount now, exhaust, ans so on...
    cody1958, LOU WELLS, Martin_F and 2 others like this.
  28. Great choice, I think a real smart decision.
  29. Atwater Mike
    Atwater Mike
    I had a '40 Coupe with a 331 Cad, ('39 box, '40 rear end) in 1959.
    The large perk of the deal was when somebody asked "What've-ya-got-in-it?" was to casually say... "CADILLAC" ....
    Just seemed to say it all!
    I installed a few Caddies in early Fords, (mostly in '29-'34s) but when asked how a Cad could possibly go into a Ford?
    It was a snap...Sut's Auto wreckers sold an adaptor, 3/8" plate cut and drilled, $16.00!
    Tex's auto wreckers had Cad/Olds stick flywheels...$8.00.
    Ford truck pressure plate/disc, and the pilot bearing: Sut's again.
    Caddy had the starter on the right side...
    That's how it was in San Jose in 1955-1965...
