Hot Rods GMC 305 v6
Discussion in 'The Hokey Ass Message Board' started by badgascoupe, Dec 13, 2020.
  1. 302GMC
    302GMC
    from Idaho
    Don't need no engine to pull my hose ....
  2. MO54Frank
    MO54Frank
    Old Waylon on YouTube is building a custom 38 GMC truck with a V12. He’s been working on it for months and still has a ways to go.
    Some might find it interesting.
  3. junkyardjeff
    junkyardjeff
    A friend had a 60 one ton panel with one of those V6s,he put too much oil in it and it spun a bearing so I got involved in changing the engine. Took a engine out of a cab over to put in it and found out after it was in that the water pump sat too high and would have been through the hood,he worked county fairs and loaded it to the max and it worked great for him.
  4. 55blacktie
    55blacktie
    Sounds like there is no shortage of hose pullers.
  5. GlassThamesDoug
    GlassThamesDoug
    My 305E is coming out this Fall even thou it runs great, starts every time. The 7mpg and 55mph is no more. Designed in 50s... for incredible durability and lugging capability, the low 7.5 cr helps lugging. Cooling system holds 32qts...virtually impossible to overheat with 170hp. The heads have similar ports to a 409... so poor mpg for both seems fitting. A stock CST 402 315hp BBC going in so I can drive on freeway.
    XXL__ and TrailerTrashToo like this.
