I have a 62 ford unibody truck. Several years ago l was in a hurry to get it on the road. Well long story short l got a generick aluminum fuel cell and mounted it in the bed. It has a gm float and my gauge is ford. Any easy way to make it work?
swap out the sender. Or put a 10 ohm resistor in series with the GM sender, and read the gauge backwards. If you have a 30 ohm sender, it will be kind of close, but if you have a 90 ohm it might not be quite what you want. At least it's cheap to try it.
I actually have the sender out of the tank. I tryed a old ford one that was in another tank but didnt bend it properly to work. Thank you for the replys
Well my cheap ass multimeter will not read the ohms. It will read it but, l can take the leads off and get a totally different reading the next time l hook it up!
Oh yea the resistance changes like it is supposed to on the float. My multimeter just gives me a different reading each time l try it.
what kind of numbers do you see? Can you get it to settle down somewhere near the full end of the scale? It should be either close to 30 ohms, or close to 90 ohms.
Long time ago, when a buddy added a extra tank to his '60 something Ford PU, we cut the sender apart and reassembled it with the rheostat upside down to get around the gauge reading backwards problem; but we were young and stupid and didn't know you couldn't do stuff like that.
It may be giving you different readings because of the location of the wiper on the variable resistor being different each time. If you haven't yet, try your reading with the float all the way up and all the way down. You probably have the 0-90 ohm float. If so, you will read inverse of what the gauge indicates, but you will stay on E a long time, and run out of gas between 3/4 tank and full. Do like Jim did and remark the gauge or just know that it is backward and use as is.
Yea in my first life after hs when l was trying to get college educated l was a electronics tech. It has been a few years but, l kinda remimber how to use a multimeter. The cheap one l has shows different values when the float would be in the empty position
Tanks has a device that lets any gauge work with any sender. it's kinda expensive at $136 , but would save a lot of messing around. i think having a working and accurate fuel gauge is important i've never used one , i'd like to hear from someone who has http://www.tanksinc.com/index.cfm/p...ct_id=473/category_id=62/mode=prod/prd473.htm
I just purchased a product which functions exactly like the one from tanks from Spiyda Design in England. Cost was about $56 including shipping to USA. They have videos on line showing the operation. Haven't installed it yet as I just got it Thursday. It is called the Gauge Wizard MK3
Or add a gas gauge that matches the sender.....or, get a gas gauge that can be programed to match any sender's ohms range(without even knowing what the sender's range actually is). Speedhut makes them I'm told.
