Hot Rods GM 64-5 electronic distributors
Discussion in 'The Hokey Ass Message Board' started by 325w, Dec 30, 2018.
  1. can these distributors be converted to common points distributor?
  2. Budget36
    Budget36
    I didn't know GM had electronic distributors then, what's it out of? I'd like to see a pic if you don't mind.
  3. gimpyshotrods
    gimpyshotrods
    Like a K66? If so, why? Those go from $600-1800 to the Corvette guys!
    If you just want the mechanical tach drive, you can get a repro for $200, or a used/partial points one for about the same, and come out way ahead.
  4. DDDenny
  5. squirrel
    you can connect the K66 distributor to an MSD box, and it should work fine...at least, it did for me.
    But yeah, sell it and buy a couple dozen point distributors with the money.
  6. big duece
    big duece
    from kansas
  7. DDDenny
    The K66 optional ignition was available on the 66 Nova 327/350 hp engine.
  8. It's in a GTO. It looks like a points distributor. Just wondering since it seems there are no parts out there. Unless the Chevy module is the same. Window sticker shows it as extra cost option.
  9. gimpyshotrods
    gimpyshotrods
    Do you have a picture of the guts? It might be the same one, with a housing to fit the native application. If so, it might me worth as much, or even more than a K66.
  10. gimpyshotrods
    gimpyshotrods
  11. No pictures. I've not taken the cap off . It runs great right now.
  12. gimpyshotrods
    gimpyshotrods
  13. squirrel
    if it runs great, leave it alone...if you're worried about it quitting, get a stock points distributor to keep as a spare, and a few pieces of wire so you can wire it in.
    das858 and gimpyshotrods like this.
  14. Looked at the link someone provided. Next time I'm over to the house I'll take a picture to compare. Have not found the module that appears o mount on the firewall either. May have been changed already however it's not listed in the pages of the cars history.
  15. Elcohaulic
    Elcohaulic
    I had one in a 64 Pontiac Grand Prix with a 421. It was a royal pain in the ass so I swapped it for a single points distributor.. Looking back, I think the 421 had Packard 440 wires and that was causing all the issues.. That swap also taught me about resisters cause I was going through points like crazy.. lol
  16. Fordors
    Fordors
    Check the wiring into the rubber grommet in the bottom of the distributor. If there is one wire (factory will be black) connected to the negative (-) side of the coil you have points. Check the link that big deuce provided, the K66 will have two wires going into the distributor grommet that connect to the wiring harness.
  17. Finally an update. Bought points and stuff for the GTO. Took the cap off and it's the electronic dist. So I still cannot find the module? Anybody have a clue where it mounts on a GTO? I have books for the car but cannot seem to find where the box locates.
  18. squirrel
    post a picture of the distributor, with the cap off. Or just verify it is the original pickup, find pictures of an original transistor distributor and compare.
    The module for the original transistor ignition is pretty large, a cast aluminum box. There's also an electronic voltage regulator (originally)
  19. Fordors
    Fordors
    It might be mounted to the front of the core support, GM said they were heat sensitive.
  20. 41rodderz
    41rodderz
    from Oregon
    Of course it was an option .:D Was there any other engine ? j/k
  21. Has the electronic voltage regulator. I bypassed that. Change to an internal regulated alt.
  22. squirrel
    sure would be neat to see what's in the distributor, so we can help you figure this out
  23. treb11
    treb11
    Is anyone building a clone of the control box with modern internals?
    Sent from my SM-G965U using The H.A.M.B. mobile app
  24. Ebbsspeed
    Ebbsspeed
