Technical Gauge Panels- 3 hole, 4 hole, 5 hole?
Discussion in 'Traditional Hot Rods' started by Dreddybear, Oct 27, 2014.
  1. Dreddybear
    Dreddybear
    Ever see a 5 hole or larger? I'm talking the underdash all in a line panel.
  2. I've seen the 4 but never anything with more 5 or more holes. HRP
  3. alchemy
    alchemy
    Moon made a panel with a flat flange on top that held a large in the middle and two smaller on each side. They may have had a similar panel with two large in the center for six in a row.
  4. Shamus
    Shamus
    from NC
    Stewart-Warner "Hollywood" with original restored Wings gauges & a so called "Classic" or "Navigator". Had planned to use the "Hollywood" in my '34 roadster but just couldn't bring myself to cut that perfect original dash. IMG_5369.JPG IMG_5797.JPG IMG_5797.JPG
  5. John walton
    John walton
    Would you happen to have a spare winged "fuel level "gauge that you would sell? Thanks John email [email protected]
    Tomkat39 likes this.
  6. Muttley
    Muttley
    Yep, Moon did indeed make those. I'll try and scan one of their old catalogs tomorrow if I can.
  7. mikeymike
    mikeymike
    O'Brien Truckers make a five hole gauge under dash panel; they also have a neat Champion Gauge Panels.
    Look at www.obrientruckers.com.
  8. In my opinion a "real car" needs a minimum of 5 gauges. Speedometer, gas, oil, temp and ammeter. I wouldn't expect 5 under the dash since most are already in the instrument panel. After that maybe a tachometer, vacuum and a couple of extra temperature gauges but they are just frosting on the cake.
    Charlie Stephens
  9. 4-holer with aviation style gauges, switch, and start button in Bill Helbing's '34 - circa 1950
  10. Shamus
    Shamus
    from NC
    Sorry - just the one in the panel. I will sell the whole panel, plus the tach drive Mallory distributor that I had Bubba convert for a flathead.
  11. pinkynoegg
    pinkynoegg
    I've got a 4 hole panel from back in the day but have not run across the 5 panel some are talking abuout
  12. landseaandair
    landseaandair
    from phoenix
    Sold this one a while back, could swear I've seen them in old Moon ads.
    Hotrodmyk likes this.
  13. davesvintage
    davesvintage
    Stewart Warner 4 hole underdash with 3 light pods in original box.
  14. Muttley
    Muttley
    From the 1962 Moon catalog:
  15. Muttley
    Muttley
    And some enlarged scans just in case..........
  16. alchemy
    alchemy
    And there you go. LOTS more undermounts than we ever remembered. Old catalogs are so cool!
    porknbeaner likes this.
  17. Alchemy
    I agree 100%, you just can't beat an old catalog for the gee I don't remember that value.
    In answer to the original question I am a '60s kid pretty much and for an over the counter ancillary gauge panel I don't remember seeing anything more then 4 gauges. Normally on the street what you saw were 1 single or a triple. I used to like a pair of doubles, they were easy to find on the rack at the parts counter because no one ran doubles around where I lived and I could run a pair of gauges on wither side of my column, but I have been informed that I am not normal. :eek:
  18. Dreddybear
    Dreddybear
    You guys rule. I have a whole mess of blue gauges I want to run and not enough room! I need to find a way to run 7..
  19. I've been called normal, Abby Normal. LOL
  20. ynottayblock
    ynottayblock
    Dreddy, have you considered putting the gauges in the header panel above the windsheild?
    This is a bad example, but shows you what I mean. Norwell did the same on his Diamond Deuce pick up
  21. pinkynoegg
    pinkynoegg
    kick panels, trans tunnel, trunk, header panel, back of the cab going into trunk, door panels....didnt you start that funky places thread a while back?
  22. Dreddybear
    Dreddybear
    I have, And I think it's awesome but I don't think my particular setup lends itself to this method very well. Jeff's pickup is one of my faves!
    Oh they will be going in those places too!
  23. Well buddy you know as well as I do that it ain't no real hot rod unless it has gauges on the firewall. :D
