try using toilet bowl cleaner. I used it a couple of times and it works fine. let it set for a couple of hours then rinse with hot water and spray with wd 40. add a little water and slosh it around a few time. Mike
Drop a small chain in there with it when you start sloshing... that'll help knock the big chunks loose!
Yeah, and the sparks it creates in there will add that little extra bit of suspense that makes life so exciting.
First clean the petroleum products out with a soap or alcohol, I use Castrol Super clean or Joy Dish soap, then clean the rust with muriatic acid, wear gloves and a respirator, rinse with water and then alcohol to remove the water.
