Hey! don't know if there is s commercial solution but thought i would show how i solved the problem with the French Flathead loosing oil through the 59a oil pan breather. first i welded the breather shut but had problem with the engine spitting oil from every hole or seal. logic if you think about it. same with a pcvavle so maybe pcv was too small. who knows. finally reactivated the breather. this is the hole i am talking about following is my first try but didn't like it and wasn't tight with an oring below it second try with oring sealing in blocks hole and with height adjustable bolt plus jamnut. put a rubber cap on the bolt to protect the underside of the intake from scratches. by this you can make sure it stays positioned by the intake plus can be adjusted to "inner" height of intake e.g. if i ever change to the dog bone. its got 17mm inside diameter up to the 6 holes. mathematically i would only have needed 5 holes but this way they won't be the issue.. if there is any. at the oring i kept 2,5..3mm of meat for it not to break. here it is installed with the holes to the walls to avoid splash oil from the gallery. it compresses the oring firmly but doesn't shear it.maybe it would even stay without the bolt. gases should get out. took some minutes to adjust the bolt to the intake with intake gasket installed. . jammed it and here we are. so yeah that's it. tell me what you think
