Technical Frame VIN
Discussion in 'The Hokey Ass Message Board' started by GonzoMN, Apr 25, 2016.
  1. GonzoMN
    GonzoMN
    Looking at a 39 Ford Coupe.
    Does this VIN look funny?
  2. alchemy
    alchemy
    Looks like it's messed up with weld?
  3. Bruce Lancaster
    Bruce Lancaster
    Assuming a *18 just to the left of the--, it would be a correct '39 V8 serial...but looks like the guy on the assembly line was drunk, and then someone with welder and grinder added some trouble...
  4. I agree with Bruce. Here is the location to find serial numbers: http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm
    Does the vehicle still have the original transmisson? The same number should be stamped into the transmission case but the DMV doesn't like to use it since it is easy to change transmissions. Although they wouldn't want to use the number from the transmission it might help convince them that they are reading the number on the frame correctly. Worst case the number appears two more places (see the bottom of the page on the site I referenced) under the body. Just lift the body and let them see these numbers (easier said than done).
    Charlie Stephens
  5. Jalopy Joker
    Jalopy Joker
    those letters, numbers, star stamped on frame are each done free hand. is that the number on the title? I see a couple of what appear to be rivet heads, no welding. off to the right of one rivet is the number 4 - more numbers there? not called VIN but, identification or serial numbers.
  6. Bruce Lancaster
    Bruce Lancaster
    Sure looks like frame! Big rivits!!
  7. tfeverfred
    tfeverfred
    Looks like 2-5 years, depending on the court and the judge.
    Bandit Billy likes this.
  8. Mr48chev
  9. I have never heard you could read the numbers without removing the body. Might be good to ask on fordbarn.com and earlyfordv8.org. To quote from the above reference "The locations at the middle and rear of the frame are normally covered up by the body and not visible until the body comes off."
    Charlie Stephens
  10. big duece
    big duece
    from kansas
    Appears that there are two different height numbers? Even though they are freehand stamped, all vin's I have seen are the same height.
    roundvalley likes this.
  11. roundvalley
    roundvalley
    Big Deuce is correct. Looks like the #8 and the first #3 have been redone for some reason.
  12. big duece
    big duece
    from kansas
    The original "8" is there, but just a poor restamp. The "3" and possibly the "1" could also have be reinstalled because of welding or grinding, but used the wrong height stamp. The "6" font is correct.
  13. GonzoMN
    GonzoMN
    Number matches title.
  14. 36brothers
    36brothers
    Suspicious, what else can you say. Tread lightly.
